Lighting sorceress
Tylr
Gold: 48.30
Clan: COME AT ME BRO
Post#1 Posted: 29 Jun 2008 03:03 am    Post subject: Lighting sorceress Reply with quote
Here's a guide for those who have been looking for a lightning sorceress guide on jsp.
There are two approaches when making a lightning sorceress:
1. ES Build
2. Vita Build
With
the ES build, you will be using energy shield to allow you to take a
lot of hits, but your damage will suffer as a result. You will be
maxing telekenesis, putting a lot of points into energy shield, and
will be using mana as your life.
With the Vita build, you will be doing a lot of damage (40-50k+) , but will have a harder time staying alive.
You
will be putting all your skills into Lightning, mastery, and its
synergies, and will be relying on high vitality to stay alive.
Basically,
If you are rich, either build will work for you. If you are not
rich yet, I'd recommend going with the vita build, because an es build
just won't produce enough damage output, and you will not have enough
life/mana for es to be effective.
For either build, this is your ideal gear:
Helmet- Griffon Eye (the best one you can get (-res is more important for a lite sorc)/Shako (if you can't afford a griff)
Amulets-Armageddon Fletch/Maras//Tals ammy
Weapon-HOTO (the higher resistances, the better)
Sheild- Spirit Shield (try to get a 35fcr)
belt - Arach
Gloves- Frostburns/Magefists
rings- 2x sojs/fcr rings with mana and/or resist
boots -Sandstorm Treks
Armor- Chains of honor archon plate(defense,resistance,skills,all around best for sorc)
Weapon Switch
CTA (The Higher Battle Orders, the better)
Spirit Shield (any crap spirit is fine here)
Optional:
+9ES staff
+3 ES ormus
(use these for prebuff ES)
You
can also put in a low strength infinity polearm instead of hoto/spirit
for a lot more damage, but at the cost of resistances mana, and fcr.
Iventory:
8x Lightning Gcs with Life
1x Lightning Gc with FHR
Sorc Torch
Anni
9x Life/Mana Scs
1x fhr/mana sc
(The best you can get with these charms...they do cost a bit)
Some FCR Breakpoints you may want to look at:
63 FCR
105 FCR
200 FCR
and some of the FHR Breakpoints you want to hit:
42 FHR
60 FHR
86 FHR
142 FHR
The
set up i gave was a 105fcr/86 FHR. I recommend that combination,
because it provides good fcr and fhr while still allowing you to have
plenty of +skill items and life/mana. However, if you wan more fhr or
fcr, you can mix the gear/ fhr gcs around to hit your desired
breakpoints.
Merc: Act 2 Nightmare Defensive (Holy Freeze) is the best merc for your lightning sorceress.
Eth
Andariel's visage: Aim for High lifeleech, strength, and put a ral in
it to negate the fire resist penalty. (You can also use a gaze here if
you are planning to use a CA infinity)
Eth Ca/Cv Infinity: High -enemy resist and ed are important here
Eth Fort: The more resistances/life per level/defense, the better
1. For the ES build, here are your skills and stats:
Str: enough to wear gear
Dex: None
Vitality: 100-150
Energy: Rest
(experiment
with the Vitality/Energy Combination... Make sure you have enough
vitality so that poison or open wounds can not kill you too quickly,
but at the same time make sure you have enough energy to absorb the
other hits. I find that 100 vita is good if you can afford light lifer
skill charms, and 150 if you can not afford them.)
Skills:
Frozen Armor: 1 Point
Warmth: 1 Point
Thunderstorm: 1 Point
Static Field: 1 Point
Teleport: 1 Point
Telekenesis: Max
Energy
Shield: 7 Points (This should add up to lvl 40 after ES ormus, es
staff, gear, and charms...if you're short, feel free to add but don't
exceed 40 after gear)
Chain Lightning: Max
Lightning: Max
Lightning Mastery: Max
Rest into Nova or Charged Bolt
2. For the Vita Build, here are your skills and stats:
Str: Enough to Wear gear
Dex: None
Vitality: Rest
Energy: about 100
Skills:
Warmth: 1 Point
Teleport: 1 Point
Lightning: Max
Nova: Max
Charged Bolt: Rest
After Charged Bolt is maxed, you can put the rest of your points into thunderstorm (if you plan to level your character past 93)
PVM
Strategy: Zap the crap outta everything with chain lightning vs.
multiple enemies and regular lightning vs. single enemies. Beware of
oblivion knights in act 4 and act 5... if iron maiden hits your merc,
better get to town fast and get
to a healer because if he dies,
conviction is gone and you will suck. Teleing around often will also
keep your merc from getting hit from conviction.
PVP Strategy:
Not sure if this is BM, but I like to go with a voulge infin with
magefist, fletch, vipermagi, arach, 2x sojs, treks, and griffon so i
can have 105fcr and conviction without use of a merc. You'll lose some
resists and mana here, but you'll gain a crapload of damage. Tele
around...if you're cheap let the ts and convict kill your enemy (100%
success rate with that), if you're not, hit him with a lightning and
he's dead 1 hit GG.
Don't like voulge infin? Ok. I'll take more
mana fcr and resists then. Slap on your frostburn, tele around, and hit
him with lightning once or twice and he's dead. GG
Good
luck! the Lightning Sorceress is one of the best characters for
dueling, mfing, rushing, chaosing, and baaling. It's one of the most
versatile characters in the game and you can never go wrong with a well
made lightning sorceress.
_____________________
ONCETHEREWASALINKHEREANDNOWITISGONEYES
D4L.
Down for life.
Gold: 27.12
Post#2 Posted: 29 Jun 2008 03:06 am    Post subject: Reply with quote
Good guide, but that's from d2jsp.
Ordinator
Group: Banned
Gold: 3.38
Warn: Banned
Banned
Post#3 Posted: 29 Jun 2008 06:42 am    Post subject: Reply with quote
3 light 10 fcr ammy >tals + maras since u get good enough res from coh
or some good 2 sorc 15fcr str life mana ammy
_________________
Tylr
Gold: 48.30
Post#4 Posted: 29 Jun 2008 06:49 am    Post subject: Reply with quote
i didn't make this.
this is from a d2jsp guide that i thought i would post on here for people to use.
lol.
Ordinator
Group: Banned
Gold: 3.38
Warn: Banned
Banned
Post#5 Posted: 29 Jun 2008 07:07 am    Post subject: Reply with quote
WELL WHOEVER WROTE IT IS A RETARD THEY FORGOT ARMOR FOR THIS BUILD
wait i forgot light sorcs dont use armors
nvm
_________________
Tylr
Gold: 48.30
Post#6 Posted: 29 Jun 2008 10:18 am    Post subject: Reply with quote
nvm
Haha.
Thanks for telling me that
Fixed it cool
cheesypizza
Group: VIP
Donor:
Gold: 0.00
VIP
Post#7 Posted: 17 Jul 2008 10:41 pm    Post subject: Reply with quote
Call me strange, but I enjoy this energy build...
Gear:
Dusk Nigma
Spirit Monarch
Hoto
Frosties/mages
Griffs
Maras
2x Sojs
Eth Treks
Arach
Okay why nigma? At lvl 90 you got yourself like 68 str points! Thats 68 more in energy.. plus you will have 65% frw with treks, 5% to life, added mf for the hell of it, 8% damage reduction.. so on..
120% FCR, without the mages (mages will give more mana regen!)
mad dam with 9x skillers and plenty enough of -res with facet in griffs and a infinity on merc..
Maras, Sojs, Griffs, Arach, Spirit, Hoto give pluses to BO with cta (a shit load more)
Youll have max res, and if not pretty damn close, nothing a 1-2 res scs cant fix
Arachs, frosties, sojs all give more to mana!
Dump all extra points in energy after 156 str at lvl90 for spirit obviously.
None anywhere else.
Skillz: Nothing but one point in warmth, one in frozen armor (helps save ur ass alot) and then max out in lighting damage skills. No need to put anymore then one in energy shield, OR telekeneis because you will already have over 3.5k mana if not way more and regenerating very fast! You should be able to take a hit from anything and tele away to regenerate to attack again.. works like a charm.
an easy 50k plus dam at this lvl. with max res, close to 4k mana, mad regeneration..
I know this was typed fast, but I didnt want to write a book, just share how I build my light sorcy.. pm me for any more info if I forgot anything.
ManBearPig
Group: Banned
Gold: Locked
Warn: Banned
Banned
Post#8 Posted: 18 Jul 2008 09:42 pm    Post subject: Reply with quote
Nice Guide Bro Thx a lot! ima try this in my free time XD
_________________
2 Members: Guest
Page 1 of 1
