| Author |
Message |
TheVoid
Group: Members Joined: 29 Apr 2013 Posts: 34 Gold: 3.50
Status: Warn:  Reputation: 0
#1 Posted: 29 Apr 2013 12:36 pm Post subject: BMPK v3.0.6 Endgame |
Welcome, welcome. This is TheVoid#2 @ EoN, and 0bjectivity @ d2jsp. I know this is my first post, however, this is the only forum that it seems it will allow for sales of programs.
Anyways, to the juicy stuff.
EDIT OCT 5 2014: VIDEO:
https://www.youtube.com/watch?v=mCa8TzhZClk
Long story short, I’m looking to make cash off this game, so without further ado, allow me to present
“BMPK v3.0.1”
Amongst a plethora of other screenshots.
So what are the exact feature lists?
Well, first, here is a screen shot of the folder of all items, and configurations you will receive:
Here are the contents of all the configurations.
AURASHIFT.INI:
| Code: | ## Based on internet speed, and your connection to the servers, will be the amount of aurs that you can equipt accuractly, whilst, still duel without interruption.
## Those that do not know, these are the optional auras that are "flashed" that will give your mercenary / allies, a considerable damage boost for a slight second or two.
## Aura shifting triggers everytime you teleport, then activates when equipting concentration.
## PALADINS ONLY##
[Auras To Activate]
Might = "true"
Fanaticism = "true"
Blessed Aim = "true"
Thorns = "false"
Conviction = "false"
Defiance = "true"
Vigor = "true" |
BREAKPOINTS.INI:
| Code: |
[Break Point Settings]
FCR = "150"
FHR = "255"
FBR = "255"
IAS = "150"
ChangeLog.txt
| Code: |
## Just starting the changelog after 2.5.1
Version 2.5.2
- Fixed a bug where the TMC boost screwed up on paladin charge.
- Fixed TP Tome bug where BMPK wouldn't use another TP tome from stash or cube after the first one was empty.
+ Added "NG Message" a simple, yet effective way to spam a quick message with optional self statistics -> "BMPK.ini"
+ Added Precasting. The fastest way to prebuff and go! -> Presets.ini
+ Lightning TMC, bypassing the "SEQUENTIAL" frames. Lightning Trigger Happy Sorces.
+ Switched the required item to TP and JUV from stash from a large charm to a Ring, so classic characters won't experience a crash when attempted.
+ Added "ThunderStorm" to prebuff list. Thunder Storm wasn't announced when casting it on the console.
+ Added Red/Purple/Blue colors to Potions on ground
+ Added Monster Warning spam on TPing ( optional )
+ Added Unique Monster's names on minimap
+ Changed the authcheck to only check your character authorization once, after that, BMTPPK will work on any char, you must use an authorized character for the first authorization though! This was implemented to allow faster create games / and join games, without the need to require access to bmpk.net
Version 2.5.3
- Fixed a minor bug where some precasting skills were still attempted while not allowed to be casted other than outside. (Hurricane, Thunderstorm, etc)
- Fixed direct attack AutoAim vs BlindSpot Attack Autoaim on Enemy Paladin.
+ When using Precasts, it will set back the skill you had before you precasted, when the precasting has ended.
+ Added Completed Auto ReTeleport ( Blindspot for Paladins, and WhirlWind EndPoint for Assassins and Barbarians )
Version 2.5.4
+ Fine tuned the Attack Player / Attack Nearest Player / Attack Monster distance to the max distance possible. 1.6ft gain.
+ Added KICK as the SMITE attack. Allowing all characters to use knockback.
Version 2.5.5 - Sad update Hah!
+ Added SC / HC Filtered PKLOGGING. Enjoy Friend PKPOINTS vs all bmpk members!
+ Removed the inability to use auto reblind/kick/AA on bmpk members.
+ TeleWalk to player now uses your current blind spot. ( Blind 5 for telestomp)
Version 2.5.6
-Fixed 2 crashes when trying to use the auto precast when a player says defined sentence.
-Fixed a memory leak on auto smite / kick. CPU usage went up to 100% while in use.
-Fixed auto kick once again. This time, we should have no more crashes, even in most hostile conditions.
+ Added the ability to change the in game slain message of "X was slain by X" to whatever you want. Complete with custom "was slain by" message, and coloring. -> Presets.ini
+ Added the animation on precasting, kicking, and auto reblinding. Please take some time to configure the "PreCast delay" speed, as it affects both speeds.
+ Added showing the % life of a player, when he or she exits the game.
Version 2.5.6 beta 1
- Removed animation with reblind. Was far too buggy. Awaiting further bugs. AA bug is still not addressed.
+ When activating an AUTO, you no longer have to worry about NORMAL ATTACK being set on left or right sides.
Version 2.5.6 beta 2
+ Removed Animation from AA. Read Closely. It now uses packet AA, everything you AA will be invisible. On top of this, you have a new delay. AA delay. When you spam Packets, only a few are real, aka showing 1000 hammers in 2 seconds.
You will need to edit the Delay that best suits what you want to get used to. For example, you can have 0 delay, but then you will have to train yourself to kinda think when is the next time you can spam AA, imagining in your mind when would a legit tele animation end.
If your delay is high, it will take that long before you can hit AA again, so don't set it to like 3000 ( which is 3 seconds ), you will not be able to AA again after 3 Seconds.
This should completly elminate all AA Attacking bugs.
Version 2.5.7
+ Yet again, I have switched the Auto Aim back to normal, I recoded the mess myself from the ground up, I have not errored yet, and until I do, or you do, I declare the AA flawless.
I appologize for the worthless packet AA.
+ Added Broadcasting, allows you with an option of disabling, to show your game name / char name / and account when joining a game on the front page of BMPK.Net. Presets.ini.
+ Fixed monster slain when using a custom slain message.
- Removed the config Packet AA for obvious reasons.
Version 2.5.8
+ Fixed up Monster AA with the same recoding for PVP AA, AA should be thoroughly flawless now.
+ Fixed a bug where if using blinds, then trying to use another attack other than teleport, you would constantly miss the target.
You may now have blinds on, and AA with other skills and hit your target. ( Thanks Ben ).
+ As per request, Middle Mouse may now be set to player AA if so desired.
+ As per request, Monster Names may now be removed in the maphack section.
+ Cleaned up and removed useless functions, TPPK, Camping, etc.
+ Fixed Flashing Bug, no longer required to use ,reload to get flashing working.
+ Made the Conc/Hammer and Charge / Vigor keys no longer display the error above your head, but rather on the console.
- Bug with chant bot, if they are too far away, you will crash when they activate a command. Too lazy to fix after I already did the above fixes, maybe next time ;).
- Bug with custom X Slain By Y message, if someone dies to a monster, it gets really funky stuff printed out. Same reason as above why don't feel like fixing.
Version 2.5.9
+ Seems the AA bug with PVP was NOT fixed, I have yet again implemented a NEW fix, and still have not crashed, the previous versions still experience the AA crash, we'll see if I got it this time.
+ No longer need an individual DLL for each user. I have made it so 1 DLL Fits all!
+ Changed the UI of a little as a teaser for future updates.
+ Changed TMC to be completly compatible with ALL skills.
+ Increaded the Precast precision. Precasting with BUFF skills, should be 100% accurate now.
Version 2.5.9 Beta 1
+ Added ability to use Kick or Smite with Auto Smite.
+ Recoded Reblind and Kick, with severe customizations -> Bmpk.ini
+ Yet again added some things for the notorious AA bug, this is why I'm declaring this a beta 1, try to crash my AA.
Version 2.6.0 Final
+ Officially out of beta, we are convinced I have finally nuked the AA bug. Hooray!
+ Added Antidote Potion Chicken. -> Bmpk.ini
+ Fixed a minor logic bug with Smite / Kick.
+ Fixed a Precast bug, should be 100% flawless now.
Version 2.6.1 Final
+ In game Pk logging! Simply type ,score after a few games, and view a nicely organized list of kills!
+ Added gold dropper, idk, just for lols I guess. -> Presets.ini
Version 2.6.2 Final
+ FarCast Teleport. - Status: Finished!
Self explaining.
+ Artificial Intelligence Monitoring - Status: Finished!
Monitors all players in game and allows for 1 warning per player, per game, which resets on a new game joined, or game left.
+ Portal Block - Status: Finished!
When your life if below your tp%, you won't be able to accidently go back into portal.
+ Auradin Warning! - Status: Finished!
When BMPK detects a character with Holy Fire / Holy Shock, it will town you and alert you who and what aura was used. In conjuction with Artificial Intelligence.
+ Free Roam TeleWalk - Status: Finished!
Press the hotkey, and you will auto telewalk to where your mouse position is.
+ Potion usage - Status: Finished!
When a player uses potions, mana, health, you will be alerted.
+ Hotkeys for various commands ex: blind spot change, reload config - Status: Finished!
+ Fixed Gold Dropping that would error when you ran out of gold. Now it will just stop dropping.
+ Fixed auto reblind causing a crash when left on and leaving game.
+ Blind Spot teleing now ends up at the end point of where they charge, at the end of their charge, you will be on their blind spot.
+ Turned off other reblinds, when another one was activated, while another was still in use.
Version 2.6.3 Final
+ Fixed targetlist where when the target left, the "Current Target" would turn out blank, it will now always say "No Target"
+ Selected target is now Evil Red.
+ Added Anti-Spam improvement, squelching a player will automatically add its name to the spammer list.
+ Fixed custom message removing 1 space before the whole death.
+ Fixed monster giberish when death by monster.
+ Fixed double death msges when dieing period.
+ Improved the custom X was Slain by X within presets.ini.
+ %life of players now toggleable on map -> Bmpk.ini
+ Fixed Aura Detection to only warn you if the player is unhostile.
+ Added Status of BO / Not Bo'd / and Barb BO on minimap, completly toggleable via config -> Bmpk.ini
+ Added %life and the name of an owners TP on the minimap
+ Added Complete legit screen shotting.
+ Added commands .fcr <number> and .ias <number> to increase or decrease your base FCR / IAS respectivly.
+ Added FULL GUI Customization.
+ Fixed Attack Player Hotkey, it SEEMS to be fixed, I did a quick test, no crash. If it does, please let me know.
+ Moved the hostile symbol below custom / original GUI, with the cost of permanently removing GUI Options for : SERVER IP, and GAMESLEFT
+ Optimized Reblind / Auto Smite
+ Made the config for reblind and smite simpler.
Version 2.6.4 Final
+ Fixed a memory leak with custom GUI
+ Added Collision Checking to Farcast teleport.
+ Added Smite After X Reblinds, and Option to Teleport on their blind spot right after smite during reblind.
+ Added Teleport on blind spot after Auto Smiting.
+ Fixed a Teleport bug, causing a random crash.
+ Fixed Blocking Portal, will only block portals now, due to MPQ lookup.
+ Added Various options for reblind / smite.
+ Added custom Join / Exit / Hostile options.
+ Must Use NEW Config. Thanks.
Thanks to Mac(IRTSB) and Trev(WOrm) for severe testing.
Version 2.6.5 Final
+ Added Tele Smite. Teleport on an enemy with AA, immidiatly smite / kick.
+ Fixed bug in exit msg, !acc! now says the character's account.
+ Added Left and Right AA
+ Fine Tuned all Autos, for interruptions.
+ Several other optimizations.
- Removed Attack Player Key
+ Added Communication When Needed to BMPK members when a Fix is available
+ Added another safty check for the Autos.
+ Fixed Immune bug with Left AA.
+ Fixed TMC Issues.
Version 2.6.7
+ Added AutoScreenShot to capture erotic deaths of players.
+ Added advance AutoScreenShot Capture techniques and options.
+ Player crosses on minimap are editable to distinguish BMPK Member / Hostile / Nuetral , etc more easily.
+ Middle Mouse now switches to teleport for you for farcasting, and executes teleport in the direction on your mouse.
+ Middle Mouse may now be held down for the same effect.
+ Recoded Reblind.
+ Fixed a bug with Hostile Town Chicken.
/// Added Commands 'Presets.ini' ///
[In Game Kill Message]
Enable AutoScreenShot = "true"
Turn Off Map For ScreenShot = "true"
Only ScreenShot Blacklist? = "false"
Wait For DeathMsg Completion? = "false"
AutoScreenShot Delay = "200"
ScreenShot Radius = "10" ## Enemy must be in "x" units from you, on death, for a screenshot. Use "0" to disable.
Use 'Alt' In ScreenShot? = "false" ## Allows for Ear + Gold to be displayed during death.
/// Added Commands 'BmPK.ini' ///
[Map Hack]
Cross In party = "132"
Cross Neutral = "32"
Cross Hostile = "98"
Cross Blacklist = "0"
Cross Safelist = "168"
Cross BMPK Member = "151"
v2.6.7 Fix 1
+ several optimizations to Reblind and a new option.
- Removed Hostile custom text, interfearing with town chicken.
+ Fixed bug with update messages.
+ Added FC Tele Vector by request.
[Auto Settings]
Use Direct Teleport On Non-Paladins = "true"
[Map Hack]
Use FC Tele Vector = "true"
Cross FC Tele = "32"
Line Fc Tele = "98"
v2.6.7 Fix 2
+ Forgot to disable FCTele vector in town.
v2.6.8
+ More Reblind Optimizations.
+ Fixed bug with Reblind for non paladin characters.
+ Added detection of enemy aim on your mercenary / oak / summons to bypass traditional aim detection.
[Auto Settings]
Number Of Smites Before Towning During Reblind = "2"
## /f M Message have these additional options: !level! !class! !game! !pass!
My /f M Kill Message = "ÿc8!theslain! (A Level !level! !class!) was just romped in !game!."
v2.6.8 Fix 1
+ Fixed a bug with farcast teleport middle button causing a crash on characters without teleport.
v2.6.8 Fix 2
+ Fixed a bug with AutoReblind "freezeing" the throw skill when terminated manually.
+ Added a smoother blindspot teleport.
[GUI Customizations]
# Console + Orb Colors, Unaffaceted by "use This Custom GUI"
Box Tab Color = "8"
Box Tab Transparancy = "2"
Box Tab Text Color = "9"
Console Color = "9"
Console Transparancy = "2"
Orb Life Color = "0"
Orb Life Transparancy = "2"
Orb Mana Color = "0"
Orb Mana Transparancy = "2"
v2.6.8 Fix 3
+ Sorted about 5 more bugs with AutoReblind, that would cause being stuck.
+ Added protection from allowed a user to crash themselves with incorrect values on Transparency options.
v2.6.9
+ Bug sorted that wouldn't town correctly on Holyfire / Holy Shock detections.
+ Removed any inactive BMPK members.
+ Brand New Radio Chat Exclusive to BMPK members!
+ Added 2 commands to .help menu: .EC <on> , .Channel <1>
Use BMPK Encrypted Chat = "true"
# Only Numbers 1 - 25
BMPK Channel = "1"
v2.7.0
+ Fixed a crash with reblind while pressing middle mouse dring reblind, it will not execute farcast teleport now.
+ Fixed a crash with reblind while pressing ConcHammer / Vigor Charge keys, it will not execute now during reblind.
+ Added smooth teleportation on reblind, no more jaggedy teleports.
+ Added more intelligent Knockback / Block detection.
+ Added Jay / Kyle back to triggers.
v2.7.1
+ Should have now smoothed out every bug on reblind.
+ Added Encrypted Chat, and BMPK channel to custom game strings ( map display ).
+ Re-added TPPK by request.
+ Added the ability to remove the boarders around the boxes by large request.
Draw Boarders Around Boxes = "true"
#!ec!
Modified String Encrypted Chat = "ÿc5Encrypted Chat: ÿc1!ec!"
= "1"
#!channel!
Modified String BMPK Channel = "ÿc5BMPK Channel: ÿc1!channel!"
Modified String BMPK Channel Font = "1"
/// Added Commands 'BmPk.ini' ///
[Key Settings]
TPPK = "A"
v2.7.1 RC1
+ Added Mike to the triggers
+ Forgot to add the smooth teleporting on reblind, re-added now.
+ Smoothed out yet ever more bugs with reblind, we should finally be perfected now.
v2.7.1 RC2
+ Fixed an issue with reblind when rejoining a game when it was on, you would receive an error message.
+ Fixed another issue with reblind disabling auto aim, and other features, under certain circumstances.
+ Added a new way to address updates without changing the version number. I think its better to only upgrade the number when significant updates come out, otherwise, I note them as "hotfixes."
v2.7.2
+ Fixed any and all bugs having to do with pressing "Fast TP" and not having a Town Portal available.
##### v2.8.0 Updated to Diablo II v1.13d #######
PLEASE NOTE, I HAVE DRASTICALLY RECODED SOME THINGS.
SO PLEASE CONSIDER THIS REVISION A BETA, AND PLEASE REPORT ANY AND ALL BUGS / SUGGESTIONS
24Hour Time Format = "true"
Use Game Time = "true"
+ Added a time effect to the custom chat messages.
+ Fixed a chat encryption issue.
+ Added BO Timer. *NOTE* Barb bo is the only unaccurate timer.
v2.8.1
[Key Settings]
Start With BlindSpot AA On = "true"
Report Multiple Kills = "true" ## If true, all kills will be /f m'd not just one.
+ Early Bmpk revision due to new member 'Napster'
v2.8.2
+ Added C/I protection from clicking on an item in stash / cube.
+ Updated SpyInventory Function.
+ HostileImage corrected to fit GUI's.
+ Fixed an anti flash issue.
+ Fixed a BO Timer bug where the timer would freeze if someone other than yourself BO'd twice.
+ Trev / Dusty added to trigs. Welcome back.
v2.8.3
+ Fixed a rejuvination potion count bug.
+ Added AuraShift to Paladin teleports, and Auto reblind. ( This will automatically equip Fanta, Might, Blessed Aim, and Concentration boosting Merc Damage exponentially. )
+ Added Danny and Jay to the triggers. Welcome to BMPK.
v2.8.4
+ Fixed an issue with AuraShifting when being exited.
+ Fixed an issue with lastest version alert. It is now quick and accurate.
+ Auto teleport now shows animation.
+ Added auto enchant merc key.
+ Added instant Cube key.
+ Added the option to be able to spam AA blindspot, vs blocking multiple blind spot attacks on the same spot.
+ "Wait For DeathMsg Completion?" option now works as intended.
+ Added a function to optionally whisper the target slain victim.
- Removed the second "BMPK" logo on the map toggle.
- Removed Napster from triggers. ( Faggot ).
[Main Settings]
Don't Allow Duplicate Blind AA Attacks = "true"
[Key Settings]
Open Cube Key = "VK_7"
Instant Chant Merc With Chant Stick = "J"
Hotfix: 1
Whisper All Kills = "true"
My Whisper Message = "ÿc8 Get the fuck out of my game."
[Key Settings]
Whisper User On Next Kill = "O"
Hotfix: 2
+ Aurashift only activates if you have a merc.
v3.0.0
+ ALT key now works for auto aim.
+ GUI will now vanish during chat.
+ FC tele line only shows up when teleport is your right skill.
+ There is now a blue line with an "X" at the end of the player's clicking location.
+ Hostile Image now never goes up in the corner.
+ Map turns off during screen shots.
+ TMCPK.ini added to config files.
+ TMCPK GUI Released +
[Key Settings]
Toggle Aim Style = "O"
v3.0.1
+ Added Sorc - Element Detector to the targetlist.
+ Re-vamped AA.
+ Flashing turns on the "Flash On attack" on the GUI now.
+ Aurashifting triggers on all teleports now.
+ Mercenaries are Auto Resurrected. ( removed temporarily.)
+ Fixed an issue with FC tele teleporting in random directions.
+ Fixed an issue with an "Unhandled Error" when using FC teleport when exiting game.
+ Fixed the retarded misplacement of the shadow on the stamina bar.
+ Removed all Authorized BMPK users other than Danny / Mike. ( My fault of inactivity, please request to be reinitiated.)
+ Hammers being casted will now always hit enemies that teleport into blind 4.
+ Added AuraShift.ini
PRESETS.INI:
| Code: |
### PRESETS - Every skill that is set to "true" will be casted, IF you have it ###
### If it is set to false, even if you have it, it will NOT be casted. ###
### Battle Command will always be casted TWICE, if enabled, to give the +1 to command. ###
### ENJOY! ###
### YOU CAN REORGANIZE THE LIST HOWEVER YOU WANT FOR EASIER ACCESS ###
### "UseSentence" mostly for leech botting, if someone says this sentence, you will precast. ###
[Custom Presets]
PrecastKey = "K"
Gold Droper Delay = "0"
Activate Gold Dropper = "None"
CastDelayInMilliSeconds = "500"
UseSentence = "false"
SentenceToTriggerCasts = "bo"
Exit After Spamming Kills? = "true"
Fade = "true"
BladeShield = "true"
ShadowMaster = "true"
CycloneArmor = "true"
HolyShield = "true"
OakSage = "true"
BurstOfSpeed = "false"
Hurricane = "true"
BattleCommand = "true"
BattleOrders = "true"
Shout = "true"
FrozenArmor = "true"
ShiverArmor = "true"
ChillingArmor = "true"
EnergyShield = "true"
BoneArmor = "true"
Venom = "true"
Valk = "true"
ClayGolem = "true"
BearSummon = "true"
BearForm = "true"
WolfSummon = "false"
WolfForm = "true"
## !theslain! for slain, !killer! for killer.
Use Modified In Game Kill Messages = "true"
AutoScreenShot Delay = "100"
My Whisper Message = "ÿc5 Get the ÿc8fuck ÿc5out of my game."
My /f M Kill Message = "ÿc5 New victim ->ÿc8!theslain!ÿc5<-- in game ÿc8 !game!."
Modified String My Kill = "ÿc0!theslain! was ÿc;slaughtered ÿc3 by Bmpk Member TheVoid"
Modified String My Death = "ÿc3!theslain! was slain by !killer!"
Modified String Rand Slay Rand = "ÿc0!theslain! ÿc3was slain by ÿc0!killer!"
[BroadCasting Options]
Allow Latest Use To Display Account? = "true"
Allow Latest Use To Display Character? = "true"
Allow Latest Use To Display Game? = "true"
##Fonts from 1 - 13
Use This Custom GUI = "true"
Use Custom Chat Messages = "true"
Use BMPK Encrypted Chat = "false"
BMPK Channel = "12"
Box Tab Color = "155"
Box Tab Transparancy = "1"
Box Tab Text Color = "8"
Console Color = "155"
Console Transparancy = "0"
Orb Life Color = "2"
Orb Life Transparancy = "8"
Orb Mana Color = "2"
Orb Mana Transparancy = "8"
Use Game Time = "false"
24Hour Time Format = "false"
#!me! !mychat! !time!
My Chat Message = "[!time!] ÿc3!me!: ÿc0!mychat!ÿc0"
#!char! !theirchat!
Their Chat Message = "[!time!] ÿc3!char!: ÿc0!theirchat!"
#!char! !acc! !class! !lvl!
Join Game Message = "ÿc3!char! ÿc0(ÿc3*!acc!ÿc3)ÿc0 Came To Die.ÿc3 ~ ÿc0!lvl! ÿc3~ ÿc0!class!"
#!char! !acc! !class! !lvl! !life!
Exit Game Message = "ÿc3!char! ÿc0(ÿc3*!acc!ÿc3)ÿc0 Dodged. ÿc3~ ÿc0!life!%ÿc0 ~ ÿc3!lvl!ÿc3 ~ ÿc0!class!"
#!char!
Hostility Message = ""
#!game!
Modified String Game Name = "ÿc3Game: ÿc0!game!"
Modified String Game Name Font = "4"
#!pw!
Modified String Game PW = "ÿc3Pass: ÿc0!pw!"
Modified String Game PW Font = "4"
#!area!
Modified String Area = ""
Modified String Area Font = "1"
#!diff!
Modified String Difficulty = ""
Modified String Difficulty Font = "1"
#!gversion!
Modified String Game Version = ""
Modified String Game Version Font = "1"
#!expansion!
Modified String Expansion = ""
Modified String Expansion Font = "1"
#!rxp!
Modified String Remaining EXP = ""
Modified String Remaining EXP Font = "1"
#!gxp!
Modified String Gained XP = ""
Modified String Gained XP Font = "1"
#!time!
Modified String Time = ""
Modified String Time Font = "1"
#!xpp!
Modified String Exp Percent = ""
Modified String Exp Percent Font = "1"
#!juvs!
Modified String Juvies = "ÿc3Juves: ÿc0!juvs!"
Modified String Juvies Font = "4"
#!tps!
Modified String TPS = ""
Modified String TPS Font = "1"
#!ping!
Modified String Ping = "ÿc3Ping: ÿc0!ping!"
Modified String Ping Font = "4"
#!fps!
Modified String FPS = "ÿc3Fps: ÿc0!fps!"
Modified String FPS Font = "4"
#!ec!
Modified String Encrypted Chat = ""
Modified String Encrypted Chat Font = "4"
#!channel!
Modified String BMPK Channel = "ÿc1Yÿc2a ÿc3Dÿc4iÿc5Gÿc6?ÿc7!ÿc8?ÿc9!ÿc0?"
Modified String BMPK Channel Font = "4"
####### COLOR CODES ##
####### Some of these May not work. Try them. ##
####### ( Must use "ÿc" before the code number) ##
####### 1 = Red ##
####### 2 = Green ##
####### 3 = Blue ##
####### 4 = Gold ##
####### 8 = Orange ##
####### - = White ##
####### : = Dark Green ##
####### 0 = White ##
####### 5 = Grey ##
####### 6 = Black ##
####### 7 = Gold ##
####### 9 = Yellow ##
####### ; = Purple ##
####### - = Bold ##
TMCPKGUI.INI
| Code: |
[TMCPK Variable Colors]
Bracket Color = "2"
Dash Color = "2"
Function Color = "1"
Function Value Color = "4"
Current Target Color = "8"
Target List Neutral Player Color = "0"
Target List Hostile Player Color = "1"
Target List Allied Player Color = "2"
Game Timer Color = "1"
Bo Timer Color = "1"
## For Console / Console Outline Colors, use the COLOR chart from the HTML.
[TMCPK Console]
Console Color = "5"
Console Outline Color = "32"
Console Transperancy = "155"
[TMCPK Life And Mana]
Life Coordinate X = "105"
Life Coordinate Y = "500"
Mana Coordinate X = "765"
Mana Coordinate Y = "500"
LifePercent Coordinate X = "145"
LifePercent Coordinate Y = "550"
LifePercent Font = "5"
ManaPercent Coordinate X = "805"
ManaPercent Coordinate Y = "550"
ManaPercent Font = "5"
Everything is customization, as you have seen in the configuration settings, death messages, what's shown on kills, /w messages, everything is editable.
I feature TMCPK's GUI layout, and yes I am the programmer of this product.
So how do I purchase?
Well, you must meet this criteria:
- Own a Paypal VERIFIED account.
- You will send payment as a "gift."
- Buyer of course pays the fees.
- You must be OK with the fact that this program is locked to 1 PC, aka, you, the buyer, will not be able to run BMPK on any PC other than the one specified through our conversations.
PRICE:
$30 / per PC for the lifetime of the product with instant updates, through dropbox. You will need to setup a dropbox ( www.dropbox.com )account to receive instant updates.
When purchasing from me, you will be required to download teamviewer if you come across any errors, if I cannot fix it to the point where you can just use the program as intended, I will issue a full refund.
You will also be required to speak to me via AIM / MSN: [email protected] ( yes, for both messangers).
Those that would like live demonstrations, can catch me livestreaming here:
www.twitch.tv/TheAirForce
Thanks for your interest! Please add me on a messanger and message me with the message "I am interested in purchasing BMPK, I saw your ad on d3jsp."
Thank you!
| Back to top |
TheVoid
#2 Posted: 29 Apr 2013 12:36 pm Post subject: |
Wouldn't fit on first page so:
BMPK.INI:
| Code: |
## BMTPPK 3.0.1 PRIVATE For Diablo II (v1.13c) Lord Of Destruction ##
## Very Special Thanks To Cody/Steve/Isaac/Sheppard/Andy For Coding These!
## Thanks @ Steve for paying for www.bmpk.net!
## Thanks to all BMPK Members supplying kills for our site <3
## Enjoy!
[Main Settings]
Fast Teleport = "true"
Speed Hack = "true"
Remove Portal Delay = "true"
Hostile Target Only = "false"
Anti-Minimize = "false"
Auto Clean Screenshots = "true"
Farcast Enabled = true
Full Light Radius = true
Show Item Levels = "true"
Show Item Sockets = "true"
Show Item Ethereal = "true"
Aim Box Enabled = "true"
Aim Box Color = "32"
Spam Delay = "50"
Blind Spot = 4
Console Delay = "5000"
StrBugFix = "true"
OverHeadTrace = "true"
ShowMemberName = "true"
SaveGameNameAndPW = "true"
Use Monster Warnings = "false"
[Extra Town Options]
TownOnIronMaiden = "false"
TownOnAmp = "true"
TownOnLowerResis = "false"
TownOnBoOut = "true"
TownAfterKill = "false"
BlockPortalEntryOnLowLife = "true"
TownOnHolyFireDetect = "true"
TownOnHolyShockDetect = "true"
[Auto Settings]
Auto Tele Smite = "None"
Max Time To Wait Before Resetting TeleSmite = "500"
Teleport On Enemy After Smite With TeleSmite = "true"
Auto Reblind Paladin Teleports = "U"
Reblind Attempts Before Smite = "0"
Use Smite? = "false"
Teleport On Enemy After Smite With AutoBlind = "false"
ReblindDistance = "10"
Max Time To Wait Before Resetting Autoblind = "1000"
Auto Smite On Enemy Teleport = "Y"
Teleport On Enemy After Smite With AutoSmite = "true"
Max Time To Wait Before Resetting AutoSmite = "1000"
Auto Teleport On Barbarian Endpoint WhirlWind = "E"
Interruption Option = "2"
# During the event auto smite / telesmite / reblind is Interrupted, meaning they hit you strongly, or block, here are options.
# 0 = Do nothing allow the auto to take its course. ( Not Recommended ).
# 1 = Immediately Reset the Auto
# 2 = Town
# 3 = Exit
[Middle Click Options]
Use FarCast For Middle Click? = "true"
Use Monster AA For Middle Click? = "false"
Use Nearest Player AA For Middle Click? = "false"
Farcast Distance = "50"
## anywhere from 40-50 is nice, experiment what works best.
[Key Settings]
Command Trigger = ">"
Window Control Key = "VK_CONTROL"
TPPK = "A"
Fast Portal Key = "G"
Open Portal Key = "L"
Open Stash Key = "VK_9"
Spy Target Inventory Key = "VK_0"
Auto Party Toggle Key = "VK_F9"
Auto Aim Slot Toggle Key = "VK_NUMPAD0"
Screen Hooks Toggle Key = "VK_NUMPAD1"
Teleport To Player Key = "VK_NUMPAD2"
Hostile And Teleport To Player Key = "VK_NUMPAD3"
Last Target Key = "VK_NUMPAD4"
Next Target Key = "VK_NUMPAD6"
Blind Spot Toggle Key = "VK_DECIMAL"
Silent Exit Key = "VK_SUBTRACT"
Hostile Key = "VK_ADD"
View Console Logs Key = "VK_F11"
View In Game Config Key = VK_F12
Flash Target Key = "B"
Clear Console Key = "V"
Fast Exit Key = "VK_6"
Attack Nearest Player Right = "C"
Attack Nearest Player Left = "None"
Attack Nearest Monster Right = "None"
Attack Nearest Monster Left = "V"
ConcHammer = "z"
VigorCharge = "X"
Next BlindSpot = "None"
Reload Config = "None"
Hold+Click To Tele Walk = "F"
Report Next Kill To Friends = "O"
End Point Charge Tele = "None"
Toggle Aim Style = "None"
[Winamp Settings]
Stop Key = ""
Play Key = "VK_HOME"
Next Song Key = "VK_PAGEDOWN"
Prev Song Key = "VK_PAGEUP"
Print Title Key = "VK_END"
Winamp Text = "Current Song"
[Auto Teleport Settings]
Next Vector Key = "VK_NUMPAD9"
Last Vector Key = "VK_NUMPAD7"
Waypoint Vector Key = "VK_NUMPAD8"
Special Vector Key = "VK_NUMPAD5"
Next Vector Color = "155"
Last Vector Color = "109"
Waypoint Vector Color = "132"
Special Vector Color = "152"
[Enchant Bot]
Enchant Bot Toggle Key = "None"
Enchant Me String = "chant"
Enchant Merc String = "chantmerc"
Enchant All String = "chantall"
Whisper Join Messages = "true"
Use Auto Party = "true"
[Map Hack]
Auto Reveal Map = "true"
Draw Monster Blobs = "true"
Draw Monster Immunities = "true"
Draw Missiles = "true"
Draw Teleport Vectors = "true"
Draw Aim Vector = "true"
Draw Level Names = "true"
Normal Monster Color = "98"
Champion Monster Color = "151"
Boss Monster Color = "155"
Draw Monster Names = "true"
My Missile Color = "32"
Display Player Life = "true"
Display No Bo = "true"
Display Barb Bo = "true"
Display Hostile Curses = "true"
Display Life On Tps = "true"
Cross In Party = "132"
Line Fc Tele = "98"
[Chicken Settings]
## 0 = Off, 1 = Town, 2 = Tele, 3 = Exit, 4 = Warn
On Hostile = "0"
On Namelock = "0"
Town Life = "70"
Quit Life = "50"
Town Mana = "0"
Quit Mana = "0"
CheckSafe Town = "false"
CheckSafe Rejuv = "false"
Use Antidotes = "true"
[Potion Settings]
Use Auto Potion = "true"
Drink Life = "85"
Drink Life Rejuv = "80"
Drink Mana = "10"
Drink Mana Rejuv = "0"
Life Potion Delay = "2500"
Mana Potion Delay = "2500"
Rejuv Delay = "250"
ShowPotionsUseOnScreen = "true"
ShowPotionsUseOnConsole = "true"
[Messages]
Print Chicken = "true"
Print Command Echoes = "false"
[NG Message] // Exiting game will spam this first then exit.
// !time! for current game timer
// !xpremain! for xp remaining
// !xppercent! for xp percent
// !xpgain! for amount of gained xp
// !gamesleft! amount of games left to level
// !song! current winamp song
// !him! current target
// !me! current character name
Use NG Message = "true"
Line 1 = "www.ClanBmPk.net"
Line 2 = "Where the bigger fish roam."
Line 3 = ""
Line 4 = ""
Line 5 = ""
Line 6 = ""
Line 7 = ""
Line 8 = ""
Line 9 = ""
Line 10 = ""
Line 11 = ""
[Spam Message]
## !song! = winamp string
Spam Key = "H"
Line 1 = " @@@"
Line 2 = " @ @"
Line 3 = " @@@"
Line 4 = " @ @ @@ @@"
Line 5 = " @@@ @ @ @ @"
Line 6 = " @ @ @"
Line 7 = " @ @ @@@"
Line 8 = " @ @ @ @"
Line 9 = " @ @ @@@"
Line 10 = " @ @ @"
Line 11 = " @ @ @"
Line 12 = " @ @@"
Line 13 = " @ @"
Line 14 = "You've been Bmpk'd @ @"
[Death Message]
## !me! = your character name, !him! = dead player name, !song! = winamp string
## !score1! = kill count in game, !score2! = kill count since load
Use Death Message = "true"
Line 1 = "!him! es one ez!! o.o!!"
Line 2 = ""
Line 3 = ""
Line 4 = ""
Line 5 = ""
Line 6 = ""
Line 7 = ""
Line 8 = ""
Line 9 = ""
Line 10 = ""
Line 11 = ""
Line 12 = ""
Line 13 = ""
Line 14 = ""
Line 15 = ""
| Back to top |
Jeff
Group: Loser Joined: 23 Jul 2012 Posts: 3573 Gold: Locked Clan: Weed
Status: Warn:  Reputation: 30
#3 Posted: 30 Apr 2013 11:40 pm Post subject: |
goodluck selling lol worse hacks ever, if any1 wants good hacks i will give u hacks 10x better project 2.0, can have any1 scan it will even post it on here if needed (free)
no need to pay for something that sucks lol |
| Back to top |
Dean
 Group: Members Joined: 23 Jul 2011 Donor:  Posts: 49 Gold: 42.80
#4 Posted: 02 May 2013 06:10 pm Post subject: |
| D3VIL wrote: | goodluck selling lol worse hacks ever, if any1 wants good hacks i will give u hacks 10x better project 2.0, can have any1 scan it will even post it on here if needed (free)
I highly doubt your programming skills exceed Steve's one.
I'm pretty sure you would give people a "2.0" as you say aka 1.3 with login interception & or cheaply crypted Keylogger stub
tl;dr:Don't spam his topic |
| Back to top |
TheVoid
#5 Posted: 04 May 2013 04:59 am Post subject: |
| Dean wrote: | | D3VIL wrote: | goodluck selling lol worse hacks ever, if any1 wants good hacks i will give u hacks 10x better project 2.0, can have any1 scan it will even post it on here if needed (free)
Thank you. |
| Back to top |
Creep
 Group: VIP Joined: 17 Jan 2012 Posts: 802 Gold: 55.30
Status: Warn:  Reputation: 46
#6 Posted: 04 May 2013 05:09 am Post subject: |
| Back to top |
relinquished
Group: Members Joined: 24 Mar 2013 Posts: 48 Gold: 5.30
Status: Warn:  Reputation: 1
#7 Posted: 04 May 2013 05:27 am Post subject: |
| Travis wrote: | Vouch your mod steve.
Goodluck with selling,
I am a bmpk user myself and It is a great mod.
well worth the buy. |
Vouch, im a user too, last screenshot is my kill |
| Back to top |
No_Noobs
Group: Members Joined: 13 May 2013 Posts: 1 Gold: 0.00
#8 Posted: 13 May 2013 06:52 am Post subject: Trusted, |
im using it,
VOUCH!
| Back to top |
Kyle
 Group: Members Joined: 12 May 2011 Posts: 16 Gold: 2.10
#9 Posted: 15 May 2013 07:34 pm Post subject: |
| lmao |
| Back to top |
relinquished
#10 Posted: 20 Jun 2013 01:41 am Post subject: |
| bumb |
| Back to top |
FSM
Group: Banned Joined: 17 Jun 2013 Posts: 50 Gold: Locked
Status: Warn: Banned Reputation: 1
#11 Posted: 20 Jun 2013 07:33 am Post subject: |
Will you sell the source code?
Last edited by FSM on 20 Jun 2013 07:48 am; edited 2 times in total _________________ This user's signature has been disabled |
| Back to top |
ansvarig
Group: Scammer Joined: 20 Nov 2011 Posts: 28 Gold: Locked
#12 Posted: 25 Jun 2013 11:24 am Post subject: |
| Does the "tppk" funktion works with this? I mean u hit å button and i run to town and pk? |
| Back to top |
FSM
#13 Posted: 25 Jun 2013 02:31 pm Post subject: |
| ansvarig wrote: | | Does the "tppk" funktion works with this? I mean u hit å button and i run to town and pk? |
Tppk has long been patched. It will only work with a couple, very slow moving, skills. Even then there is a chance it won't work. _________________ This user's signature has been disabled |
| Back to top |
ansvarig
#14 Posted: 26 Jun 2013 04:16 am Post subject: |
| Okej thx for info.. and what is slow skills? That work? |
| Back to top |
FSM
#15 Posted: 26 Jun 2013 12:07 pm Post subject: |
| ansvarig wrote: | | Okej thx for info.. and what is slow skills? That work? |
Sometimes fissure and fire leftover from meteor work. _________________ This user's signature has been disabled |
| Back to top |
ansvarig
#16 Posted: 26 Jun 2013 01:08 pm Post subject: |
| I have heard somthing about necro revive. . Claws of viper. Somthing about dmg clouds |
| Back to top |
TheVoid
#17 Posted: 01 Jul 2013 05:30 am Post subject: |
| BMPK is now currently v3.0.3, and has a plethora of upgrades especially towards the topic of PVP, pM me if interested, serious inquiries only, otherwise it's just ignored! |
| Back to top |
TheVoid
#18 Posted: 25 Jul 2013 01:18 pm Post subject: |
Thanks for those who have purchased thus far.
BMPK is still being updated, and improved, PM me with any questions if interested!
Unlimited Spam, death, exit, and whisper messages!
DEATHMESSAGES.INI
| Code: |
#### Long Awaited Random Death Messages #####
# "Number Of Death Messages" will determine how many death messages you are supplying, any number from 1 - you heart's desire. #
# You will need to Create a "[Death Message 1]" then "Line 1 = "blah blah"" for every death message you want, example will be below#
# Same with exit messages! #
# Every RELOAD / Kill / EXIT, will generate a new Messages #
# Up to 18 lines may be used where applicable. #
# Death message use only #
## !me! = your character name, !him! = dead player name, !song! = winamp string #
## !score1! = kill count in game, !score2! = kill count since load #
[Number Of Death Messages]
Number Of Death Messages = "17"
[Death Message 1]
Line 1 = "======================================================"
Line 2 = "===========+++=========+++++++++++++++================"
Line 3 = "===========+++=========+++++++++++++++================"
Line 4 = "===========+++=========+++============================"
Line 5 = "===========+++=========+++============================"
Line 6 = "===========+++=========+++============================"
Line 7 = "===========+++=========+++============================"
Line 8 = "===========+++++++++++++++++++++++++++================"
Line 9 = "===========+++++++++++++++++++++++++++================"
Line 10 = "=======================+++=========+++================"
Line 11 = "=======================+++=========+++================"
Line 12 = "=======================+++=========+++================"
Line 13 = "=======================+++=========+++================"
Line 14 = "===========+++++++++++++++=========+++================"
Line 15 = "===========+++++++++++++++=========+++================"
Line 16 = "======================================================"
Line 17 = "HEIL, MEIN FUHRER. SIEG HEIL!"
[Death Message 2]
Line 1 = " ___"
Line 2 = " / / 7"
Line 3 = " (_,_/\"
Line 4 = " \ \"
Line 5 = " \ \"
Line 6 = " _\ \__"
Line 7 = " ( \ )"
Line 8 = " \__\___/"
Line 9 = " EAT A DICK"
[Death Message 3]
Line 1 = " _,---._"
Line 2 = " _,-' _ )"
Line 3 = " (_.-' _.-'"
Line 4 = " _() _,-'"
Line 5 = " ( ) /"
Line 6 = " )( /"
Line 7 = " ________________ ( /)"
Line 8 = "()__)____________)))))"
Line 9 = "NIGGA GOT SMOKED"
[Death Message 4]
Line 1 = " ,---------------------."
Line 2 = " (_/| UNIVERSITY |"
Line 3 = " | OF |"
Line 4 = " | OWN |"
Line 5 = " _| DIPLOMA |"
Line 6 = " (_/_____(*)_____/"
Line 7 = " \"
Line 8 = " ))"
Line 9 = " ^"
Line 10 = "KID GOT SCHOOLED"
[Death Message 5]
Line 1 = " ,--^-------------,--------,---------,-------^--,"
Line 2 = " | ||||||||| `--------' | O"
Line 3 = " `+--------------------------------^-----------|"
Line 4 = " `\_,----------, ______________________|"
Line 5 = " / XXXXXX / `| /"
Line 6 = " / XXXXXX / `\ /"
Line 7 = " / XXXXXX /\______("
Line 8 = " / XXXXXX /"
Line 9 = " / XXXXXX /"
Line 10 = " (_________("
Line 11 = " `----------'"
Line 12 = "SHOT THE FUCK DOWN"
[Death Message 6]
Line 1 = "oooooooooo. oooooooooooo .o. oooooooooo."
Line 2 = "`888' `Y8b `888' `8 .888. `888' `Y8b"
Line 3 = " 888 888 888 .8"888. 888 888"
Line 4 = " 888 888 888oooo8 .8' `888. 888 888"
Line 5 = " 888 888 888 " .88oo8888. 888 888"
Line 6 = " 888 d88' 888 o .8' `888. 888 d88'"
Line 7 = "o888bood8P' o888ooooood8 o88o o8888o o888bood8P'"
[Death Message 7]
Line 1 = " .d888888b. 888 888 888b 888 8888888888 8888888b. "
Line 2 = "d88P" "Y88b 888 o 888 8888b 888 888 888 "Y88b"
Line 3 = "888 888 888 d8b 888 88888b 888 888 888 888"
Line 4 = "888 888 888 d888b 888 888Y88b 888 8888888 888 888"
Line 5 = "888 888 888d88888b888 888 Y88b888 888 888 888"
Line 6 = "888 888 88888P Y88888 888 Y88888 888 888 888"
Line 7 = "Y88b. .d88P 8888P Y8888 888 Y8888 888 888 .d88P"
Line 8 = " "Y88888P" 888P Y888 888 Y888 8888888888 8888888P "
[Death Message 8]
Line 1 = " /´¯/)"
Line 2 = " ,/¯../ /"
Line 3 = " /..../ /"
Line 4 = " ....../´¯/'...'/´¯¯.`·¸"
Line 5 = " /'/.../..../.....:^.¨¯\"
Line 6 = " ('(...´...´....¯_/'...'/"
Line 7 = " \.................'...../"
Line 8 = " '\'...\.........._.·´"
Line 9 = " FUCK YOU"
[Death Message 9]
Line 1 = " ( ( ) ) ) "
Line 2 = " /|x x| - BMPK~"
Line 3 = " /\( - ) "
Line 4 = " ___.-._/\/ "
Line 5 = " /=`_'-'-'/ !! "
Line 6 = " |-{ _-} ! "
Line 7 = " (-{ _-} ! "
Line 8 = " \{_ _} ! "
Line 9 = " } _-} "
Line 10 = " {-_|-_} "
Line 11 = " {-_|_-} "
Line 12 = " {_-|-_} "
Line 13 = " {_-|-_} "
Line 14 = "____%%@ @%%_______ "
[Death Message 10]
Line 1 = " | / | \/ Get Lynched "
Line 2 = " (_____) By BMPK "
Line 3 = " (_____) "
Line 4 = " (_____) "
Line 5 = " (____ ) "
Line 6 = " / /\ "
Line 7 = " / , ^./\ "
Line 8 = " / / \ \ "
Line 9 = " / / \ \ "
Line 10 = "( ( ) ) "
Line 11 = "| | | | "
Line 12 = "| | | | "
Line 13 = "| | | | "
Line 14 = "( ( ) ) "
Line 15 = " \ \ / / "
Line 16 = " \ `---' / "
Line 17 = " `--------' "
[Death Message 11]
Line 1 = " ,---------. / "
Line 2 = " ,' `. ,--' "
Line 3 = " ,' `. ,-;-- _.-"
Line 4 = " pow! / \ ---;-' _.=.---'' "
Line 5 = " +-------------+ ; X X ---=-----'' _.------- "
Line 6 = " | ----- |--| \-----=---:i- "
Line 7 = " +XX|'i:'''''''' : ;`--._ ''---':---- "
Line 8 = " /X+-) \ \ / / ''--._ `- "
Line 9 = " .XXX|) `. `. ,' ,' ''---."
Line 10 = " X\/) `. '---' ,' `-"
Line 11 = " \ `---+---' "
Line 12 = " \ | "
Line 13 = " \. | "
Line 14 = " `----------------------+ "
Line 15 = " KILL YOURSELF PLEASE! "
[Death Message 12]
Line 1 = " ___________"
Line 2 = " \ /"
Line 3 = " )________("
Line 4 = " |""""""""""|_.-._,.---------.,_.-._"
Line 5 = " | | | | | | ''-."
Line 6 = " | |_| |_ _| |_..-'"
Line 7 = " |_______| '-' `'---------'` '-'"
Line 8 = " )"""""""""("
Line 9 = " /________\"
Line 10 = " `'----------'`"
Line 11 = " .------------."
Line 12 = " /___________\"
Line 13 = " CASE DISMISSED!"
[Death Message 13]
Line 1 = " /\ /¯¯¯¯¯¯¯\ /\ /\ /\"
Line 2 = " / \| |:\ \ / \ / \ / \"
Line 3 = "|\ |::| | / / |\ \ |\ \"
Line 4 = "|:| |::/ /| | | /¯¯¯¯¯\ /¯¯¯¯¯¯\|:| | |\¯¯¯¯¯¯¯\| |"
Line 5 = "|:| |/ /::| |\ \/ /| | / /|\ \/ /| |:| |\_____/|"
Line 6 = " \| (:::'| |:\_____/:/ /| / /::|::\____/::| |:| ¯¯¯|::|:|"
Line 7 = " | |\ \:/ /¯¯¯¯¯¯¯\/ /:| | |::|:::|:::::|::| \| |¯/¯¯¯¯¯¯¯¯¯\"
Line 8 = " | |::\ \ / /| /::| |\ \:/\|\¯¯¯¯¯¯\ | |/ /|\ \"
Line 9 = " | |::::\ \ / /:/ /::::/ |::\ \ |:| \ /_______ /::|:| |"
Line 10 = " / /|\::::| | | |/ |:::/ |::::\ \./ \ |::::::::::::|:::|/ /:|"
Line 11 = " |\ /::| \/ /| |\_______/|\ \:/ \:::::\_____/|\ /| |::::::::::::|:::/|\ /:::|"
Line 12 = " |::\/::::| |\ /:| |:|::::::::::|:|::\ /| \::::|::::::|:|::\ /::||::::::::::::|:/ |::\ /::::|"
Line 13 = " |::|::::/ |::\/:::| |:|::::::::::|:|::::\/::| \::|::::::|:|::::\ /::::| ¯¯¯¯¯¯¯ |::::\/::::::/"
Line 14 = " \::|::/ |::|:::/ \|::::::::::|/ \::::|:::| \|::::::|/ \::::|::::/ \::::|::::/"
Line 15 = " \|/ \::|:/ ¯¯¯¯¯¯¯ \::|::/ ¯¯¯¯ \::|::/ \::|::/"
Line 16 = " \|/ \|/ \|/ \|/"
[Death Message 14]
Line 1 = " _==/ i i \==_"
Line 2 = " /XX/ |\___/| \XX\"
Line 3 = " /XXXX\ |XXXX| /XXXX\"
Line 4 = " |XXXXXX\_ _XXXXXX_ _/XXXXXX|"
Line 5 = " XXXXXXXXXxxxxxxxXXXXXXXXxxxxxxxXXXXXXXXX"
Line 6 = "|XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX|"
Line 7 = "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
Line 8 = "|XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX|"
Line 9 = " XXXXXX/^^^^"\XXXXXXXXXXX/^^^^^\XXXXXX"
Line 10 = " |XXX| \X/^\XXX/^\X/ |XXX|"
Line 11 = " \XX\ \/ \XX/ \/ /XX/"
Line 12 = " "\ " \/ " /""
Line 13 = " May The Darkness Rise~ "
[Death Message 15]
Line 1 = " --. / |"
Line 2 = " \ \ / |"
Line 3 = " \ \ / /"
Line 4 = " \ \ | /"
Line 5 = " `\ \ | /'"
Line 6 = " _\ \/ /"
Line 7 = " ' <"
Line 8 = " / (@) \"
Line 9 = " ( |"
Line 10 = " ` . /"
Line 11 = " | ____/"
Line 12 = " (V) ==="
Line 13 = " (A)"
Line 14 = " Don't Hate The Playa"
[Death Message 16]
Line 1 = " /\ /\ /\ /\ /¯¯¯¯¯¯\"
Line 2 = " / \ / \ / \ / \| |::\ \"
Line 3 = " |\ \ |\ \ / /| |\ |::| |"
Line 4 = "|\¯¯¯¯¯¯¯¯\|:| | |\¯¯¯¯¯¯¯\| | | |:| /¯¯¯¯¯\ |:| |::/ /|"
Line 5 = "|:| |\ \/ /| |:| |\_____/| |\ \/ /| | |:| |/ /::|"
Line 6 = "|:| |::\____/::| |:| ¯¯¯|::|:| |:\_____/:/ /| \| (::::|"
Line 7 = " \| ¯¯¯|:::|:::| \| |¯/¯¯¯¯¯¯\ /¯¯¯¯¯\/ /::| | |\ \:/"
Line 8 = " | |¯¯ |::|::/ | |/ /|\ \ / /| /::::| | |::\ \"
Line 9 = " |\ \:::'|::|/ /_______ /:|:| | / /:/ /:::::/ | |::::\ \"
Line 10 = " |::\ \:'| |::::::::::::|:::|/ /| | |/ |:::::/ / /|\:::| |"
Line 11 = " |::::\ /| |::::::::::::|::/|\ /::| |\______/|\ \::/ |\ /::| \/ /|"
Line 12 = " '\:::::\ /:::| |::::::::::::|/ |::\ /::::| |:|:::::::|:|::\ /| |::\/::::| |\ /::|"
Line 13 = " \:::::\/::::| ¯¯¯¯¯¯¯ |::::\/:::::/ |:|:::::::|:|::::\/::| |:::|::::/ |::\/::::|"
Line 14 = " \::::|:::/ \::::|::::/ \|:::::::|/ \::::|::| \::|::/ |:::|:::/"
Line 15 = " \::|::/ \::|::/ ¯¯¯¯ \::|::/ \|/ \::|::/"
[Death Message 17]
Line 1 = " || || ||||||| || |||||||||| || ||"
Line 2 = " || || || ||| |||| || || ||"
Line 3 = " || || ||||||| || || || ||||||||"
Line 4 = " || //\\ || || || |||||||| || || ||"
Line 5 = " ||// \\|| || || ||| ||| || || ||"
Line 6 = " *------------------------------------------------------------*"
Line 7 = " | Gen 6:17,18 |"
Line 8 = " | And, behold, I, even I, do bring a flood of |"
Line 9 = " | waters upon the earth, to destroy all flesh, |"
Line 10 = " | wherein is the breath of life, from under |"
Line 11 = " | heaven; and every thing that is in the earth|"
Line 12 = " | shall die. |"
Line 13 = " *------------------------------------------------------------*"
## Same Deal With S/E Messages! ##
[Number of Exit Messages]
Number Of Exit Messages = "3"
[Exit Message 1]
Message = "I have to pee!"
[Exit Message 2]
Message = "OMG FUCK OFF!!!"
[Exit Message 3]
Message = "LOL, you can't kill me! I'm the gingerbread man!"
## Same Deal With Whisper Messages Messages! ##
## SINGLE LINE ONLY! ##
[Number Of Whisper Messages]
Number Of Whisper Messages = "3"
[Whisper Message 1]
[Whisper Message 2]
Message = "ÿc4 Get the ÿc8fuck ÿc4out of my game."
[Whisper Message 3]
Message = "ÿc1 Get the ÿc8fuck ÿc1out of my game."
## Same Deal With F M Messages Messages! ##
# !theslain!#
[Number Of F M Messages]
Number Of F M Messages = "3"
[F M Message 1]
Message = "New victim ->ÿc8!theslain!ÿc5<in>ÿc8!theslain!ÿc5<in>ÿc8!theslain!ÿc5<-- died in game ÿc8 !game!."
# NG message use only #
## !time! for current game timer ##
## !xpremain! for xp remaining ##
## !xppercent! for xp percent ##
## !xpgain! for amount of gained xp ##
## !gamesleft! amount of games left to level ##
## !song! current winamp song ##
## !him! current target ##
## !me! current character name ##
[Number Of NG Messages]
Number Of NG Messages = "1"
[NG Message 1]
Line 3 = " "
Line 4 = "Check out my hack in action:"
Line 5 = "www.ClanBmpk.Net/stream"
Line 6 = "Or"
Line 7 = "www.twitch.tv/TheAirForce"
Line 8 = ""
Line 9 = ""
Line 10 = ""
Line 11 = ""
# Now stop bugging me for this, fuckers.#
# - Steve #
| Back to top |
AutomaticKalashnikov1947
 Group: Members Joined: 01 Jan 2012 Posts: 176 Gold: 5.10
#19 Posted: 22 Aug 2013 07:06 pm Post subject: |
| Silly modders.. you still get failed with your crappy mods |
| Back to top |
n0.7
Group: Multi Account No Pm Joined: 29 Apr 2012 Posts: 127 Gold: Locked
#20 Posted: 29 Nov 2013 05:32 am Post subject: |
| i want buy that bmpk if no kelloger and Loader not remote.dll Pm me |
| Back to top |
