Easy fragment hunting + Midnight guide
Post new topic  Reply to topic  d3jsp Forum Index -> General Games
Bo$$
Donor:
Gold: Locked
Post#1 Posted: 26 Oct 2014 08:32 pm    Post subject: Easy fragment hunting + Midnight guide Reply with quote
Hi guys.
I just wanted to share the way of getting sacrifice sets fast and easy. It is also a great currency maker and don't have to be super end game or skilled to do this.
1. Go to Library on Merc and find the enterance to Archives
2. Create an instance
3. Once you are in archives look at your mini map, if you see a yellow door on the mini map there is 99% chance that a corrupted area has spawned. If no yellow doors on the mini map see next step
4. Go back to Library and create another instance. If no luck see step 5
5. Create a new instance of the archives untill you get a yellow door visible on the mini map.
After the corrupted zone run I run back to library and create a new archives instances untill another yeallow door spawn. It usually take up to 20 tries to get a corrupted zone. Once you master this you will be faster and faster. Corrupted zones usually spawn in 5 different places dependant on witch side you land in the Archives and the position of the doors on the map (up or down)
How to get midnights?
Once you have mastered the library/archives method you just run the fragments as a normal map untill you get midnights dropping from the corrupted area.
This way I could earn 10-20 Exalted Orbs each day for the past few weeks.
Have fun!
/edit
forgot to mention. This doesn't work if you are in a party
ZhayZhay
Gold: 2.90
Post#2 Posted: 02 Jun 2016 04:04 pm    Post subject: Reply with quote
its this really effiecient? O.o
2 Members: Guest
Post new topic  Reply to topic  d3jsp Forum Index -> General Games All times are GMT - 4 Hours
Page 1 of 1
