Max dr/Max block necromancer
1, 2, 3  Next
Parasola
Group: Banned
Gold: Locked
Warn: Banned
Banned
Post#1 Posted: 18 Oct 2008 05:40 pm    Post subject: Max dr/Max block necromancer Reply with quote
This guide is for nva.
Stats he should have by the end:
75% block
50% dr
3k+Life ( with self bo)
125fcr
86fhr.
Stats:
str-> enough for gear ( i have base str cuz i have los of str gear ,enigma is a major help there as well)
Dex-> do this right after you got your gear on. Make sure you reach your maxblock .
Vita -> rest
Energy- > o
Skills:
20 teeth
20 bonespear
20 bone spirit
20 bone armor
1 into amp ( for team duels)
1 into iron golem ( nice slow down effect)
10 into bone wall
10 into bone prison
if you get more vlvls just max bone wall or prison
Gear i suggest:
weapon:
Hoto -> skills/fcr/res
Stash:
spirit sword v( for extra mana/fhr)
8bs 6bs white ( for nvn)
wizzy -> for extra res
Armor:
enigma hands down -> life/dr/skills/frw/teleport
Rings:
i use 2 x 10fcr str dex rings with 3x life
but 1 x fcr ring+ bk or soj works as well
Boots:
You can find many boots for necros all work good:
drw/fhr/dex /tri res boots
Treks
Waterwalks
etc.
Ammy:
Try to find something like storm circlet
2necro 20fcr/usefull stats (str/dex/life/res)
belt:
arach
Helm:
2/20/str/dex/life/res circlet:
put 2 x shaels inside ( For fhr)
Gloves:
trangs
Shield:
Storm shield -> with ber in it ( 43dr/cbf/str/ your main nva shield)
stash:
any fcr monarch for nvn ( with your gear ull reach fcr bp anyway)
switch:
6 bo cta
spirit
Inentory:
torch anni
2x 12fhr pnb gcs
7x 45lifer pnb gcs.
1x 5fhr/5res sc
9x 20/5 life/res scs.
Stash:
9x 20/11 cr scs
9x 20/11 lr scs
Stash:
Abasorb gear: ( only use for bm)
tgod
2 x wisps
2x dwarfs
hospurs
#4, Strategies:
NOTE: I will not tell very much, its boring + you have to find ur own playstyle
How to make invisible spirit / spears (also works on fireball sorcs and all chars with missiles):
Its all about shooting when ur enemy is _NOT_ on ur screen, neither on ur map (u will have to "guess" wheres hes located)
Shoot spirits in the direction u think he is / will move. he will now not see the spirits when theyr on him.
If he shows up on ur map again, and u keep send spirits, the spirits sent when he was visible on ur map, wount be invisible.
(if u did not understand, PM me. i will try to answer)
Necro Versus Trap-assasin
Use atleast 1*whisp ring, or if u ask and ur allowed use thundergods.
If whisp only, play bit more defensive. try to make invisible spirits as explained.
If u got thundergood, or u feel u can be aggresive, then try aggro him, when he moves to lay new traps, THEN u should attack!
Necro Versus Necro (the funniest)
Mirror match, i give u 1 hint if the opponent has golem... use spear.
thats the only hint, nec vs nec is the funniest duel and i leave it out to u!
Necro Versus BvC
Just be careful when he leaps. if u wanna be uber-lame+defensive, then go some place, Spam bonewalls around you.
wait for him to come, when u see him, shoot some spirits on him, let him leap (DONT TELE AWAY), let him tele, let him whirlwind you. Just keep shooting.
The thing with the walls is, they will take 9/10 of the whirlwinds strikes. not you (lame but works).
Necro Versus bow-Amazon
Aggresive. Aggresive. tank them as fast as u can or else ur dead.
Necro Versus Java-amazon(the most boring)
I usually BM (bad manner) javazons coz theyr so boring, puting absorb etc. if u dont want, just spam spirits and avoid geting hit.
should be no problem
Necro Versus FB-Sorceress (the 2nd hardest)
Unless you dont have any absorb ur 99% dead if the sorc is energy shield 95%~~.
Just try to get in the hits so theyrs mana equal to zero, then tank them.
Note, if they use mana pots u got no chance w/o 95% res
Necro Versus LIGHT-sorceress (not as hard as Fcool
Do the same as in VS fb sorc.
Necro Versus ORB-Sorceress
(here u get use for the 20/11s cold)
Avoid geting "perfect hits". but this duel could take forever.
Necro Versus BLIZZARD-sorceress(hardest)
(20/11s cold)
Here u'r total chanceless without 1*raven, 320+ coldresist (20/11s, 115% wizz, etc)
even with this, its the hardest duel, u will die in 4 blizz with "best setup allowed"
Just try avoid the blizz, and try to be as close as possible all the time but not taking hits.
Necro Versus ELE-druid (3nd hardest)
Try teeth him first, (then oaks+wolf's dies)
Then either when wolfs+oaks dead u can just shoot after him. If he used bear(dont die of teeth) u must get a lucky namelock with the spirit. Else just spear him.
If he run away precast oak+wolfs, AGGRESIVE! get in 1 or more hits!.
Be careful, if he catch u ur 80% dead.
IF he get a namelock+hit u with tornado, Use run-mode first. click away from him _RUNNING_, then after teleport.
else u will just be stuck trying to teleport
Necro Versus Smiter(2nd-easiest)
I cant be arsed to explain all here, its very easy, abuse ur walls make a "house" to avoid he's passive charges.
Necro Versus Foh (easiest)
(20/11s light)
he got no chance with stacked resist, with wizz 115 lightres+ charms u will have 75% res After conviction.
_TANK HIM_ and he's dead fast.
Necro Versus Hammerdin
Hammerdin's are tricky... just be careful and dont be to aggresive and u will kill him.
Snipe alot
Necro Versus Hybrid-assasin
Bonewalls, be careful. try to namelock when running to make new traps.
_________________
Maddi
Group: Scammer
Gold: Locked
Clan: Playgirl
Post#2 Posted: 18 Oct 2008 06:32 pm    Post subject: Reply with quote
Personally I just go pure damage on necromancers.
Only people that hit me are elementals anyway.
Maybe a high dr build for druids but that's about it.
Better solution for javazons:
Only need 1 wisp, incase you do get hit when first telestomping.
Just decrep them, telestomp, clay golem will hit them, then spam bonespear while they try to hit you.
They'll be too slow and too busy avoiding spears or getting hit to be able to do anything.
Full 100% aggression after you curse.
My (not necessarily better) solution for barbarians:
Circle him (not in a predictable way) and keep shooting spirits into the middle of the circle (his direction). If he tries attacking he'll get hit, if he runs he still may get hit or you'll be able to chase and spear him. If he teleports and whirlwinds near you but missing, spear his ass down and he will die. Every time he makes a mistake he is most likely to get hit.
Watch him carefully, you should be able to see when he teleports by character animation, then simply move. If he spams leap, just be patient then move again and keep shooting. I've killed many of the best with this. No bonewalls, no block, and about 24% dr.
Hammerdin:
Just some additions:
If he desynchs and you have no idea where he is, spam teeth in a circle around you. Be prepared at all times to walk down or any direction if he telestomps. If you're ready, and he misses, you'll most likely get a free bonespear hit.
Necro vs Necro:
Your clay golem is your BEST friend. Golem glitch (golem on top of you or right after you tele) will make him tank the first 1 or two hits, making you basically unhittable by spear as long as you keep recasting.
Parasola
Group: Banned
Gold: Locked
Warn: Banned
Banned
Post#3 Posted: 18 Oct 2008 06:47 pm    Post subject: Reply with quote
nthx
bvc will rape you with no block.
i prefer having max dr for all annoyiung melees in private games.
Fc javazons will have time to do crap , 1 wisp wont absrb all damage .
teeth wont do too much damage to hdins. ( too slow)
this build was tested by me and doomtracker on us ladder last season
and on d3jsp ( i have it right now)
cursing barb in gm game = bm (descripfy)
ull get kicked out before you know it.
high dr for only druid LOL?
smiters, bvb, bva, zealers, pure wwsins, hybrid ww sins , Bvcs , wolf druids ,
there are tons of melee characters who will pwn you with no % block or no dr
_________________
Parasola
Group: Banned
Gold: Locked
Warn: Banned
Banned
Post#4 Posted: 18 Oct 2008 06:50 pm    Post subject: Reply with quote
i wont even go to how easily ull be raped by bowazons
with no dr/block
_________________
Maddi
Group: Scammer
Gold: Locked
Clan: Playgirl
Post#5 Posted: 18 Oct 2008 10:01 pm    Post subject: Reply with quote
Parasola wrote:
nthx
Wolf druids walk, they won't touch you
BvA are slow, they won't touch you
BvB walk, they won't touch you
Zealers and smiters charge, and they'll have enigma, so bone prison when they get near and shoot spear. If not, just teleport around spiriting. If they only tele, just avoid them easily.
Fc javazons won't have time, considering nobody can do fc perfectly. If they are using the hack then all sorb is game. 1 wisp isn't meant to absorb all damage, it's meant to tank like 2 hits or so before you're mass spearing the hell out of them.
And it all depends on what rules you play by for most curses. Anyway clay golem does plenty of slow, you don't even need the curse. Telestomp and spear down.
Like I said, I don't get touched by BvCs unless they are lucky.
Just leaves druids, which have advantage over necros, so you do need the dr.
with no dr/block
I never planned on winning against bowzons. They have advantage as it is, and you'll never ever hit them without bming.
Parasola
Group: Banned
Gold: Locked
Warn: Banned
Banned
Post#6 Posted: 18 Oct 2008 10:36 pm    Post subject: Reply with quote
nah
bvb can always put enigma on
so can bva.
wolf druids are fast with frw scs u can get hit.
i play by normal gm rules.
then you should plan more.
Boneprison+ bs spam
and wont go anywhere.
i dont know what kind of bvcs you are dueling but if they at least have a bit of skill
they would use leap + teleport
when you get close to them u get stunned name locked and in few secs they are on top of you thats where ull need dr/block.
_________________
Maddi
Group: Scammer
Gold: Locked
Clan: Playgirl
Post#7 Posted: 18 Oct 2008 10:49 pm    Post subject: Reply with quote
Parasola wrote:
nah
so can bva.
Boneprison+ bs spam
BvB with enigma = BvA
BvA with fcr = BvC
Wolf Druids will never hit me if I'm ever dueling seriously.
I know they'd use teleport, that's why you watch for when they teleport. Leap doesn't really do anything except clear the battlefield of your spirits, after he teleports from leaping you can just move again.
Do you know Austin?
Parasola
Group: Banned
Gold: Locked
Warn: Banned
Banned
Post#8 Posted: 18 Oct 2008 10:51 pm    Post subject: Reply with quote
Maddi wrote:
Parasola wrote:
nah
so can bva.
Boneprison+ bs spam
BvA with fcr = BvC
Do you know Austin?
good for you.
you dont need fcr to teleport.
i dont know Austin.
_________________
Maddi
Group: Scammer
Gold: Locked
Clan: Playgirl
Post#9 Posted: 18 Oct 2008 11:06 pm    Post subject: Reply with quote
Parasola wrote:
Maddi wrote:
Parasola wrote:
nah
so can bva.
Boneprison+ bs spam
BvA with fcr = BvC
Do you know Austin?
good for you.
i dont know Austin.
I know you don't need fcr to teleport. What's your point?
You can't expect to catch a sorceress with 0 fcr.
SeeYa
Gold: 10.50
Post#10 Posted: 19 Oct 2008 07:17 am    Post subject: Reply with quote
nice guide PROPS
Cloud
Group: Verified Member
Gold: 3.81
Post#11 Posted: 22 Oct 2008 08:01 pm    Post subject: Reply with quote
Nice guide but what gear do you use to hit 125 fcr and 86 fhr?
Maddi
Group: Scammer
Gold: Locked
Clan: Playgirl
Post#12 Posted: 22 Oct 2008 08:09 pm    Post subject: Reply with quote
What are you talking about?
It's all there.
bud_690
Gold: 2.00
Post#13 Posted: 30 Oct 2008 09:31 am    Post subject: Reply with quote
good discussion
nerds:D
ahah, im jk.
nice build.
_____________________
I Can Help With Everything. Whisper Me In Game, Or Pm Me. /w *lord_cullen
Cinemax
Donor:
Gold: 12885.33
Clan: HoD II
Post#14 Posted: 30 Oct 2008 09:45 am    Post subject: Reply with quote
Nice guide my friend, I will use this info on my next necro this week and let you know how he does.
If I accept you as you are, I will make you worse; however, if I treat you as though you are what you are capable of becoming, I help you become that.
Click to Join HOD
E-Mail: [email protected]
Verification info. Click Here
bud_690
Gold: 2.00
Post#15 Posted: 30 Oct 2008 08:51 pm    Post subject: Reply with quote
I think I'm making a Necro!
anyone got 8bs white ft? XD
nice guide.
Parasola
Group: Banned
Gold: Locked
Warn: Banned
Banned
Post#16 Posted: 30 Oct 2008 09:53 pm    Post subject: Reply with quote
nice guide.
you can just use hoto
its good to switch to 8 bs white when dueling necros but hoto works good 2
_________________
Badolzon
Gold: 7.50
Post#17 Posted: 01 Nov 2008 02:11 am    Post subject: Reply with quote
Completely disagree with your 12 fhr Gcs...
12 fhr GCs should never be used.
Here, I'll let you guess at what's better. For Fhr instead of Gcs.
Cinemax
Donor:
Gold: 12885.33
Clan: HoD II
Post#18 Posted: 01 Nov 2008 08:49 am    Post subject: Reply with quote
What the heck does that mean ?
Click to Join HOD
Kerm
Gold: Locked
Post#19 Posted: 02 Nov 2008 10:10 am    Post subject: Reply with quote
Nice Guide.
D3jsp > D2jsp
Badolzon
Gold: 7.50
Post#20 Posted: 02 Nov 2008 02:06 pm    Post subject: Reply with quote
I mean, using 5/5 scs and using 45 vita lifers instead of using Fhr gcs with 20 lifer scs is better.
2 Members: Guest
1, 2, 3  Next
Page 1 of 3
