Having issue looking for a sound card driver for this system
Juggalette
Dragon Lady
Group: Retired Moderators
Donor:
Gold: 3.30
Clan: Insane Clown Posse
Retired Moderators
Post#1 Posted: 27 Mar 2009 03:24 pm    Post subject: Having issue looking for a sound card driver for this system Reply with quote
So I am trying to find out where to get the latest sound card driver download for this setting.
Thank for any valueable information regarding this matter.
Here is a my system information ran off dxdiag.
I have Logitech 5.1 surround sound speakers.
System Information
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_qfe.061030-0020)
Language: English (Regional Setting: English)
System Manufacturer: NVIDIA
System Model: AWRDACPI
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon(tm) 64 Processor 3200+, MMX, 3DNow, ~2.2GHz
Memory: 1280MB RAM
Page File: 244MB used, 2806MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 6200
Chip type: GeForce 6200
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0221&SUBSYS_167919F1&REV_A1
Display Memory: 256.0 MB
Current Mode: 800 x 600 (32 bit) (75Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.8208 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 2/18/2009 14:44:00, 6185088 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 2/18/2009 14:44:00, 6308224 bytes
Device Identifier: {D7B71E3E-4161-11CF-515A-723600C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0221
SubSys ID: 0x167919F1
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Modem #0 Line Playback (emulated)
Default Sound Playback: Yes
Default Voice Playback: No
Hardware ID:
Manufacturer ID: 1
Product ID: 81
Type: Emulated
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
HW Accel Level: Full
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Description: Modem #0 Line Record (emulated)
Default Sound Capture: Yes
Default Voice Capture: Yes
Driver Name:
Driver Version:
Driver Attributes:
Date and Size:
Cap Flags: 0x0
Format Flags: 0x0
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Logitech Dual Action USB
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC216
FF Driver: n/a
Device Name: USB Receiver
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC50B
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x005A
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 2/18/2007 15:39:20, 59264 bytes
| Driver: usbd.sys, 8/23/2001 06:00:00, 4736 bytes
+-+ Logitech Dual Action USB
| | Matching Device ID: usb\vid_046d&pid_c216
| | Service: HidUsb
| | OEMData: 03 00 08 10 0C 00 00 00
| | Driver: hidusb.sys, 8/17/2001 12:02:20, 9600 bytes
| | Driver: hidclass.sys, 10/31/2006 09:26:12, 36864 bytes
| | Driver: hidparse.sys, 8/3/2004 21:08:18, 24960 bytes
| | Driver: hid.dll, 2/18/2007 15:46:46, 20992 bytes
| +-+ Logitech Dual Action (HID)
| | | Matching Device ID: hid\vid_046d&pid_c216
| | | Service: WmFilter
| | | Driver: WmFilter.sys, 4/12/2005 17:21:32, 22240 bytes
Gameport Devices
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/3/2004 16:14:38, 52736 bytes
| Driver: kbdclass.sys, 8/3/2004 15:58:34, 24576 bytes
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 8/3/2004 15:58:36, 14848 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/3/2004 23:01:08, 40840 bytes
+ HID-compliant mouse
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouclass.sys, 2/18/2007 15:46:46, 23040 bytes
| Driver: mouhid.sys, 2/18/2007 15:46:46, 12160 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Modem Service Provider: PCI Soft Voice SoftRing Modem with SmartSP
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: fullnet - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 9.0 GB
Total Space: 15.0 GB
File System: NTFS
Model: Maxtor 6L120P0
Drive: D:
Free Space: 3.6 GB
Total Space: 76.7 GB
File System: NTFS
Model: MAXTOR STM3160812A
Drive: E:
Free Space: 37.3 GB
Total Space: 58.3 GB
File System: NTFS
Drive: F:
Free Space: 10.2 GB
Total Space: 76.0 GB
File System: NTFS
Drive: G:
Free Space: 2.5 GB
Total Space: 43.9 GB
File System: NTFS
Drive: H:
Model: _NEC DVD+RW ND-2100AD
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/3/2004 15:59:54, 49536 bytes
Drive: J:
Model: DD1057T ZDN033P SCSI CdRom Device
Drive: K:
Drive: L:
Drive: M:
Model: CD-ROM Drive
System Devices
Name: PCI Soft Voice SoftRing Modem with SmartSP
Device ID: PCI\VEN_14F1&DEV_2F50&SUBSYS_207C14F1&REV_01\4&13699180&0&5048
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\HSF_CNXT.sys, 7.60.0000.0000 (English), 11/8/2006 13:59:30, 730112 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\HSFHWBS2.sys, 7.60.0000.0000 (English), 11/8/2006 13:59:36, 257408 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\HSF_DPV.sys, 7.60.0000.0000 (English), 11/8/2006 14:00:10, 989696 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\mdmxsdk.sys, 1.00.0002.0012 (English), 6/19/2006 11:26:58, 12672 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\HSFProf.cty, 11/8/2006 16:10:48, 144201 bytes
Driver: C:\WINDOWS\system32\mdmxsdk.dll, 1.00.0002.0012 (English), 6/19/2006 11:26:50, 94208 bytes
Driver: C:\Program Files\CONEXANT\CNXT_MODEM_PCI_VEN_14F1&DEV_2F50&SUBSYS_207C14F1\HXFSetup.exe, 4.00.0014.0000 (English), 11/7/2006 12:03:42, 708608 bytes
Driver: C:\WINDOWS\system32\Uci32114.dll, 2.00.0000.0014 (English), 11/7/2006 07:54:14, 172032 bytes
Name: NVIDIA GeForce 6200
Device ID: PCI\VEN_10DE&DEV_0221&SUBSYS_167919F1&REV_A1\4&13699180&0&3848
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0011.8208 (English), 2/18/2009 14:44:00, 6308224 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0011.8208 (English), 2/18/2009 14:44:00, 6185088 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0011.8208 (English), 2/18/2009 14:44:00, 163908 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0011.8208 (English), 2/18/2009 14:44:00, 667648 bytes
Driver: C:\WINDOWS\system32\nvcuda.dll, 6.14.0011.8208 (English), 2/18/2009 14:44:00, 1560576 bytes
Driver: C:\WINDOWS\system32\nvcuvid.dll, 6.14.0011.8208 (English), 2/18/2009 14:44:00, 401408 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0011.8208 (English), 2/18/2009 14:44:00, 9592832 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0011.8208 (English), 2/18/2009 14:44:00, 13680640 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0011.8208 (English), 2/18/2009 14:44:00, 86016 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0011.8208 (English), 2/18/2009 14:44:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0011.8208 (English), 2/18/2009 14:44:00, 229376 bytes
Driver: C:\WINDOWS\system32\nvmccsrs.dll, 6.14.0011.8208 (Arabic), 2/18/2009 14:44:00, 45056 bytes
Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0011.8208 (English), 2/18/2009 14:44:00, 4710400 bytes
Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0011.8208 (English), 2/18/2009 14:44:00, 3489792 bytes
Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0011.8208 (English), 2/18/2009 14:44:00, 188416 bytes
Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0011.8208 (English), 2/18/2009 14:44:00, 1273856 bytes
Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0011.8208 (English), 2/18/2009 14:44:00, 3796992 bytes
Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0011.8208 (English), 2/18/2009 14:44:00, 2744320 bytes
Driver: C:\WINDOWS\system32\NvPVEnc.ax, 6.14.0011.8208 (English), 2/18/2009 14:44:00, 1253376 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 2/18/2009 14:44:00, 177897 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 2/18/2009 14:44:00, 55444 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.04.0000.0033 (English), 2/18/2009 14:44:00, 135168 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.04.0000.0033 (English), 2/18/2009 14:44:00, 135168 bytes
Name: PCI Memory Controller
Device ID: PCI\VEN_10DE&DEV_005E&SUBSYS_0CA2105B&REV_A3\3&2411E6FE&0&00
Driver: n/a
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_A3\3&2411E6FE&0&70
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 16:07:48, 68224 bytes
Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_A3\3&2411E6FE&0&68
Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_A3\3&2411E6FE&0&60
Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_A3\3&2411E6FE&0&58
Device ID: PCI\VEN_10DE&DEV_005C&SUBSYS_00000000&REV_A2\3&2411E6FE&0&48
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_005B&SUBSYS_0CA2105B&REV_A3\3&2411E6FE&0&11
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.3020 (English), 2/18/2007 15:39:20, 30208 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.3020 (English), 2/18/2007 15:39:20, 143488 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/3/2004 18:56:48, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.3020 (English), 2/18/2007 15:39:20, 59264 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/3/2004 17:56:44, 7168 bytes
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_005A&SUBSYS_0CA2105B&REV_A2\3&2411E6FE&0&10
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.3020 (English), 2/18/2007 15:39:20, 17152 bytes
Name: Multimedia Audio Controller
Device ID: PCI\VEN_10DE&DEV_0059&SUBSYS_0CA2105B&REV_A2\3&2411E6FE&0&20
Driver: n/a
Name: Other PCI Bridge Device
Device ID: PCI\VEN_10DE&DEV_0057&SUBSYS_0CA2105B&REV_A3\3&2411E6FE&0&50
Driver: n/a
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_10DE&DEV_0055&SUBSYS_0CA2105B&REV_A3\3&2411E6FE&0&40
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/3/2004 15:59:42, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 15:59:44, 95360 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/23/2001 06:00:00, 3328 bytes
Device ID: PCI\VEN_10DE&DEV_0054&SUBSYS_0CA2105B&REV_A3\3&2411E6FE&0&38
Device ID: PCI\VEN_10DE&DEV_0053&SUBSYS_0CA2105B&REV_A2\3&2411E6FE&0&30
Name: SM Bus Controller
Device ID: PCI\VEN_10DE&DEV_0052&SUBSYS_0CA2105B&REV_A2\3&2411E6FE&0&09
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_0050&SUBSYS_00000000&REV_A3\3&2411E6FE&0&08
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/23/2001 06:00:00, 35840 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&2411E6FE&0&C3
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&2411E6FE&0&C2
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&2411E6FE&0&C1
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&2411E6FE&0&C0
Driver: n/a
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:42 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:42 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:42 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:42 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 06:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 06:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:50 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:50 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:04 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:04 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:50 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 06:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:58 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 2/18/2007 15:46:46 35328 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 82432 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 06:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/3/2004 17:56:44 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/3/2004 17:56:48 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/3/2004 17:56:42 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/3/2004 17:56:44 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 2/18/2007 15:37:44 498742 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/3/2004 17:56:44 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/3/2004 17:56:58 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/3/2004 17:56:44 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:44 20480 bytes
qasf.dll: 10.00.0000.4332 English Final Retail 2/18/2007 15:40:12 221184 bytes
qcap.dll: 6.05.2600.3024 English Final Retail 2/18/2007 15:38:51 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/3/2004 17:56:46 279040 bytes
qdvd.dll: 6.05.2600.2831 English Final Retail 2/18/2007 15:38:52 386048 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/3/2004 17:56:46 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/3/2004 17:56:26 733696 bytes
quartz.dll: 6.05.2600.3024 English Final Retail 2/18/2007 15:38:53 1287680 bytes
strmdll.dll: 4.01.0000.3936 English Final Retail 2/18/2007 15:39:12 246814 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/3/2004 17:56:58 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/3/2004 17:56:58 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/3/2004 17:56:44 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/3/2004 17:56:44 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/3/2004 17:56:44 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/3/2004 17:56:44 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/3/2004 17:56:44 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/3/2004 17:56:58 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/3/2004 17:56:46 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/3/2004 21:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 4096 bytes
stream.sys: 5.03.2600.2790 English Final Retail 11/4/2005 23:55:10 48768 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 20:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 20:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 20:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 2/18/2007 15:46:46 4352 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/3/2004 17:56:58 118272 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/3/2004 17:56:44 1428480 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:58 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 2/18/2007 15:46:46 17408 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/3/2004 17:56:48 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
Nero Audible Decoder,0x00200000,1,1,NeAudible.ax,4.05.0013.0000
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Nero Subpicture Decoder,0x00400000,1,1,NeSubpicture.ax,4.05.0013.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.3024
Nero Scene Detector 2,0x00200000,2,0,NeSceneDetector.ax,4.05.0013.0000
Nero Stream Buffer Sink,0x00200000,0,0,NeSBE.ax,4.05.0013.0000
Nero Subtitle,0x00200000,1,1,NeSubtitle.ax,4.05.0013.0000
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Nero3D Video Filter,0x00200000,1,1,NSG_dxFilter.dll,1.05.0002.0000
Nero Digital Audio Decoder,0x00400000,1,1,NeAudio.ax,4.05.0013.0000
DV Scenes,0x00200000,1,1,NVDV.dll,
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.3024
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.4332
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.3024
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.3024
Indeo� video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Nero FTC,0x00200000,1,1,NeFTC.ax,1.00.0000.0000
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Resize,0x00400000,1,1,NeResize.ax,4.05.0013.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3024
Indeo� video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.3024
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.3024
Nero AV Synchronizer,0x00200000,1,1,NeAVSync.ax,4.05.0013.0000
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,4.05.0013.0000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Nero Digital AVC Audio Encoder,0x00200000,1,2,NeNDAud.ax,4.05.0013.0000
Nero Digital AVC File Writer,0x00200000,1,0,NeNDMux.ax,4.05.0013.0000
Nero Digital AVC Video Enc,0x00200000,1,2,NeNDVid.ax,4.05.0013.0000
Nero Digital AVC Null Renderer,0x00200000,1,0,NeNDMux.ax,4.05.0013.0000
Nero Digital AVC Muxer,0x00200000,2,1,NeNDMux.ax,4.05.0013.0000
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,4.05.0013.0000
Nero3D Transition,0x00200000,1,1,NSG_dxFilter.dll,1.05.0002.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.3024
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.3024
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,10.00.0000.3802
Nero Digital AVC Subpicture Enc,0x00200000,1,0,NeNDMux.ax,4.05.0013.0000
Nero Format Converter,0x00200000,1,1,NeroFormatConv.ax,4.05.0013.0000
Nero Overlay Mixer,0x00200000,1,1,NeOverlayMixer.ax,4.05.0013.0000
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Nero MP4 Splitter,0x00600000,1,1,NeMP4Splitter.ax,4.05.0013.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Nero Video Decoder HD,0x00400000,3,1,NeVideoHD.ax,4.05.0013.0000
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
HighMAT and MPV Navigator Filter,0x00200000,0,3,HMNavigator.ax,4.05.0013.0000
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.3024
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Nero Photo Source,0x00200000,0,1,NePhotoSource.ax,4.05.0013.0000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Video Analyzer,0x00200000,2,0,NeVideoAnalyzer.ax,4.05.0013.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,4.05.0013.0000
DV Source Filter,0x00400000,0,1,NVDV.dll,
Nero Audio CD Filter,0x00200000,0,1,NeAudCD.ax,4.05.0013.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASX file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3802
NSC file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
Nero3D Text Effect,0x00200000,1,1,NSG_dxFilter.dll,1.05.0002.0000
Nero Video Renderer,0x00200000,1,0,NeVideoRenderer.ax,4.05.0013.0000
Nero PresentationGraphics Decoder,0x00600000,2,1,NeBDGraphic.ax,4.05.0013.0000
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.3024
Windows Media source filter,0x00600000,0,2,wmpasf.dll,10.00.0000.3802
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.3024
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero DVD Navigator,0x00600000,0,12,NeDVD.ax,4.05.0013.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2831
Nero InteractiveGraphics Decoder,0x00600000,1,1,NeBDGraphic.ax,4.05.0013.0000
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.3024
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.3024
Nero Sound Processor,0x00200000,1,1,NeSoundProc.ax,4.05.0013.0000
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,4.05.0013.0000
Nero Vcd Navigator,0x00600000,0,2,NeVCD.ax,4.05.0013.0000
Nero Audio Processor,0x00200000,1,1,NeAudioConv.ax,4.05.0013.0000
WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.4332
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Mpeg2 Encoder,0x00200000,2,1,NeVCR.ax,4.05.0013.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
Nero Audio Decoder 2,0x00600000,1,1,NeAudio2.ax,4.05.0013.0000
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,4.05.0013.0000
File writer,0x00200000,1,0,qcap.dll,6.05.2600.3024
Nero Stream Buffer Source,0x00200000,0,0,NeSBE.ax,4.05.0013.0000
Nero PS Muxer,0x00200000,1,1,NePSMuxer.ax,4.05.0013.0000
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2831
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2831
Nero Splitter,0x00600000,1,3,NeSplitter.ax,4.05.0013.0000
Nero Deinterlace,0x00200000,1,1,NeDeinterlace.ax,4.05.0013.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.3024
.RAM file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3802
Nero File Source / Splitter,0x00600000,0,3,NeFSource.ax,4.05.0013.0000
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo� audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,10.00.0000.3802
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF URL Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Processor,0x00200000,1,1,NeroVideoProc.ax,4.05.0013.0000
Nero Video Decoder,0x00600000,2,2,NeVideo.ax,4.05.0013.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
Nero Sound Switcher,0x00200000,1,1,NeSoundSwitch.ax,4.05.0013.0000
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Audio CD Navigator,0x00200000,0,1,NeAudCD.ax,4.05.0013.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.3024
Nero Thumbnail Decoder,0x00600000,1,1,NeBDThumbnail.ax,4.05.0013.0000
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2831
Nero Scene Detector,0x00200000,1,0,NeSceneDetector.ax,4.05.0013.0000
Nero Stream Control,0x00200000,1,1,NeStreamControl.ax,1.00.0000.0000
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3024
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Sample Queue,0x00200000,1,1,NeSampleQueue.ax,1.00.0000.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.3024
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.3024
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.3024
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.3024
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.3024
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.3024
XML Playlist,0x00400000,1,0,wmpasf.dll,10.00.0000.3802
Nero File Source,0x00200000,0,1,NeFileSrc.ax,4.05.0013.0000
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,4.05.0013.0000
Nero File Source (Async.),0x00400000,0,1,NeFileSourceAsync.ax,4.05.0013.0000
Nero Ogg Splitter,0x00400000,1,1,NeOggSplitter.ax,4.05.0013.0000
Nero DVD Decoder,0x00600000,2,2,NeVideo.ax,4.05.0013.0000
Nero Digital Parser,0x00600000,0,3,NDParser.ax,4.05.0013.0000
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.3024
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.3024
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.3024
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.3024
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Frame Capture,0x00200000,1,1,NeCapture.ax,4.05.0013.0000
WMplug,0x009001f4,1,1,wtwmplug.ax,
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,4.05.0013.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
HighMAT/MPV Navigator Client Filter,0x00200000,0,0,HMNavigator.ax,4.05.0013.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.3024
Nero DV Splitter,0x00200000,1,2,NeDVSplitter.ax,4.05.0013.0000
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3024
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.3024
Indeo� video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo� video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo Advanced Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo� video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.3024
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.3024
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.3024
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.3024
Intel Indeo� Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.3024
Indeo� video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.3024
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.3024
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.3024
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.3024
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.3024
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.3024
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.3024
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.3024
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.3024
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.3024
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.3024
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.3024
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.3024
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.3024
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.3024
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.3024
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.3024
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.3024
Audio Capture Sources:
Modem #0 Line Record,0x00200000,0,0,qcap.dll,6.05.2600.3024
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.3024
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
Modem #0 Line Playback,0x00200000,1,0,quartz.dll,6.05.2600.3024
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.3024
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.3024
DirectSound: Modem #0 Line Playback (emulated),0x00200000,1,0,quartz.dll,6.05.2600.3024
_____________________
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
Noctres
Gold: 2325.75
Clan: The Dude Abides
Post#2 Posted: 27 Mar 2009 06:07 pm    Post subject: Reply with quote
is this a custom built pc? if so what is the motherboard model/manufacturer
if it is a prebuilt OEM (compaq,hp,dell,etc) what is the model#?
dxdaig will not tell you this much needed info
Juggalette
Dragon Lady
Donor:
Gold: 3.30
Retired Moderators
Post#3 Posted: 27 Mar 2009 06:16 pm    Post subject: Reply with quote
Yes it is a custom built pc with winfast motherboard ( I have look at the motherboard to see what model I have, Ill edited here shortly after this post ).
EDITIED***
Ok the motherboard is winfast the # I've gotten off the motherboard in the middle is
02-01000228-62 is the first row of #
Second row on the middle of board is this :
WLKA51506373 PC K8CK804A036LRS
Then on the side where a red socket is there a # on top of it which is EA*00016cbaF73B
This is the most I know bout my board , I dont have the box for it anymore was like 2 year ago when I built this pc .
Noctres
Gold: 2325.75
Post#4 Posted: 27 Mar 2009 06:59 pm    Post subject: Reply with quote
EDITIED***
WLKA51506373 - serial number
K8CK804A036LRS
k8-amd socket
CK804A036LRS - bios/version-revision
EA*00016cbaF73B - most likely a MAC address for the nic.
keep looking, thier should be something else on there
MickHarveyandthebadseeds
Group: Banned
Gold: Locked
Warn: Banned
Banned
Post#5 Posted: 27 Mar 2009 07:44 pm    Post subject: Reply with quote
yoo understand all this??!
_________________
Noctres
Gold: 2325.75
Post#6 Posted: 27 Mar 2009 07:53 pm    Post subject: Reply with quote
yea? this is simple shiz, why?
Juggalette
Dragon Lady
Donor:
Gold: 3.30
Retired Moderators
Post#7 Posted: 31 Mar 2009 10:03 pm    Post subject: Reply with quote
Lol that 4sure , well I've gotten that cpu-z download ( that awesome btw , wish I discover that years ago ) & now I've gotten the model of the manufacturer Winfast with the model NF4K8AB . I am betting with that info I can google for the correct sound card driver smile
Thank a bunch for you help on here & via pm <3
Blessed Be ,
Seer
Juggalette
Dragon Lady
Donor:
Gold: 3.30
Retired Moderators
Post#8 Posted: 02 Apr 2009 06:00 am    Post subject: Reply with quote
Blessed Be ,
Seer
I tried & tried looking for this it still won't help me to any avail sad
Foxconn WinFast NF4K8AB-8EKRS is a pita sound driver to find ><
Noctres
Gold: 2325.75
Post#9 Posted: 02 Apr 2009 03:15 pm    Post subject: Reply with quote
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=NF4K8AB-8EKRS&TypeID=en-us0000004
file = NFref_637_w2k.zip
contains :
Audio driver version 4.57 (WHQL)
Audio utility version 4.50
Ethernet NRM driver version 4.66 (WHQL)
Network management tools version 4.66
SMBus driver version 4.45 (WHQL) with updated uninstaller files
Installer version 4.60
Win2K IDE 2.7 driver version 4.75 (WHQL)
WinXP IDE 2.7 driver version 4.75 (WHQL)
Juggalette
Dragon Lady
Donor:
Gold: 3.30
Retired Moderators
Post#10 Posted: 02 Apr 2009 03:24 pm    Post subject: Reply with quote
Awesome , awesome thank again you rock mate <3
I well let you know how it go once it install smile
Thank again for the link on that handy cpu-z tool that will help in alot of way briggrin
Noctres
Gold: 2325.75
Post#11 Posted: 02 Apr 2009 05:15 pm    Post subject: Reply with quote
Ok, Lmk
Juggalette
Dragon Lady
Donor:
Gold: 3.30
Retired Moderators
Post#12 Posted: 03 Apr 2009 12:38 am    Post subject: Reply with quote
Ok, Lmk
Every time I try to download this file , it said corrupt or invalid file .
Bo$$
Donor:
Gold: Locked
Post#13 Posted: 10 Apr 2009 03:55 am    Post subject: Reply with quote
i would visit producers website cause i dont understand a thing from what you wrote
1 Members: Guest
Page 1 of 1
