Is anyone familiar with how TMCBP affects
Post new topic  Reply to topic  d3jsp Forum Index -> Diablo II Discussion
chewster77
Group: Guild Members
Gold: 250.25
Guild Members
Post#1 Posted: 22 Aug 2007 08:32 am    Post subject: Is anyone familiar with how TMCBP affects Reply with quote
ok so, yes, i do have TMCBP, sorry i use hacks smile
anyways, i'm nosy, i have to know how things work. I'm trying to understand how TMCBP adjusts your breakpoints. I have animdata_edit_v2.1 and d2excel and have successfully adjusted tables to maximize my fcr with the gear equiped on my sorc.
it was a little tricky but i figured it out. the only thing i've messed with so far is my sorc's fcr. the table had 12 in the column and i experimented with 10, 9 and 8. 9 and 8 were too fast and wouldn't allow me to cast. i had to set it at 10 and it works fine.
my question is what is the the ias base when you change those frame rates? i have this table:
But i want to be able to add it up. For example if i change the table value to 10 does that start me off with 63 fcr with no gear and i add the fcr with my gear?
I'm just trying to figure out how this haxzor works smile
any help in explaining this would be appreciated
_____________________
cannibalrising
Donor:
Gold: 50.76
Post#2 Posted: 22 Aug 2007 08:52 am    Post subject: Reply with quote
Yes this is what it adds to you without gear. So for a sorc i would probly put at frame 8 to start with 105 fcr... Then see what gear you have and if its really high fcr drop to around 220. As far as anything elese like Fhr you dont want more than 86 with all gear and Tmc
Gentlmen Of Jsp
cannibalrising
Donor:
Gold: 50.76
Post#3 Posted: 22 Aug 2007 08:54 am    Post subject: Reply with quote
If you wanan know anything more about this pm me, This also shows the frames that the chara hits too. For example 200 fcr is max for sorc so ofcourse it allows you to put it to that BUT with gear you will have to much so i suggest you lower until you have around 200 with gear... Its this way with all charas. Frame 10 is max fcr that chara can have with gear and tmc so agguest Accordingly
Gentlmen Of Jsp
chewster77
Gold: 250.25
Guild Members
Post#4 Posted: 22 Aug 2007 09:05 am    Post subject: Reply with quote
this is my gear:
Fletch = 20 fcr
Arach = 20 fcr
Gloves = 20 fcr
Fathom = 20 fcr
so i have a total of 80 fcr in gear.
with the value set at 10 i cast at the fastes rate
so 80 + 37 = 117 (how can this be right?)
now when i set the value at 9 it casts so fast it doesn't work
so 80 + 63 = 143? which is too fast (over 256 fcr is too fast i believe)
this doesn't make sense because the highest bp is 200 and i cast fast as hell with 143
this is why i'm confused... blink
jamesnoc1
Gold: 0.50
Post#5 Posted: 18 Jan 2008 10:48 pm    Post subject: Reply with quote
hey chew could you possibly explain to me how i edit the fcr? ive tried many times and searched many sites and i cant seem to get good directions how to do this right, as i have no real programing skill im clueless.
i unederstand you change the framesperdicrection (so i have read) but what i dont understand is this, ok i open the anim 2 edit program and click on extract. Then am i supposed to open d2excel? and then what? what i did was opend excel and click on load .txt i changed the framerperdirection to 2 (just tryn to see if it works) then i save it and close the winow then click on pack. and im not seeing any difference and i did try with different fcr on the char.
2 Members: Guest
Post new topic  Reply to topic  d3jsp Forum Index -> Diablo II Discussion All times are GMT - 4 Hours
Page 1 of 1
