How to Change your IP on Windows XP
Post new topic  Reply to topic  d3jsp Forum Index -> Battlefield
Sun[shine]
Group: Banned
Donor:
Gold: Locked
Banned
Post#1 Posted: 05 Jul 2010 01:29 pm    Post subject: How to Change your IP on Windows XP Reply with quote
I had alot of problem changing my IP address, I went though weeks without jsp and it was truly horrible :/
no jk.. but. this is the one and only guide that worked for me.
Im using Windows XP with a dynamical IP, that means that the modem/router hands out the IP's.
Its copy/paste but I really dont care, I'm just trying to help y'all scrawny mothafuckas derisive
How do I change my IP address?
"How do I change my IP address?" and "Can I change my IP address?" are probably the most commonly asked questions. Please attempt the following then, if that does not work, visit the Change IP Address forum.
Before trying any other methods to change your IP address, try turning off (or unplugging the power of) your Cable/DSL modem for five minutes. In many cases this will change your IP address. However, if that does not change your IP address, repeat the process for 8 hours (overnight works well) instead of 5 minutes. Hopefully this will result in an IP change.
If the above does not result in your IP address changing, please look through the below for the situation that best matches yours and attempt to change your IP address that way. Unfortunately you are not able to get your IP address to change in all cases, as it is ultimately determined by your ISP's DHCP configuration (when you've got a dynamically assigned IP address, that is.)
Windows
- Computer connected directly to the modem
1. Get to a command prompt. (START, run, cmd).
Start Menu Run Box
2. Type "ipconfig /release" (without the quotes, on the command line by itself).
3. Type "ipconfig /renew" (without the quotes, on the command line by itself).
Windows (second option)
2. Type "ipconfig /release" (without the quotes).
3. Shut down computer.
4. Turn off computer.
5. Turn off all ethernet hubs/switches.
6. Turn off cable/DSL modem.
7. Leave off overnight.
8. Turn everything back on.
Network with Router
1. Log into the router's admin console. (Often http://192.168.1.1/)
2. Release the IP address. (Method varies by router manufacturer)
3. Turn off router, ethernet hubs/switches, and the cable/DSL modem.
4. Leave off overnight.
5. Turn everything back on.
If you are using a cable/DSL modem and a router, you may wish to connect your computer directly to the cable/DSL modem. Please note that this could significantly impact your system security. This allows your ISP's DHCP to issue you a new (hopefully changed) IP address based of the (hardware) MAC address of your computer's ethernet card.
If all the above has not worked to change your IP address and you have a router, check and see if there is a "Clone MAC Address" option. Using it should change your IP address; however, you'll only be able to do it once (in most cases).
These will not work in all cases. If all else fails contact your internet service provider (ISP) and ask them if they are able to change your IP address or how long your connection needs to be off for your IP address to change.
If you trying to change your IP address because you are just trying to access web based forums you may wish to attempt to configure your internet browser to use a proxy server.
My source - http://whatismyipaddress.com/change-ip
_________________
Vassago
Group: Otaku
Gold: 18255.34
Otaku
Post#2 Posted: 05 Jul 2010 01:37 pm    Post subject: Reply with quote
I knew a hippy named sunshine along time ago. She was such a slut.
_____________________
Shucky
Purple Swag
Donor:
Gold: 4.05
Clan: Weed
Post#3 Posted: 05 Jul 2010 02:19 pm    Post subject: Reply with quote
+0.5 fgs
Wish
Deputy Minister
Group: Banned
Donor:
Gold: 1.17
Clan: Notorious
Warn: Banned
Banned
Post#4 Posted: 05 Jul 2010 02:46 pm    Post subject: Reply with quote
Shucky wrote:
+0.5 fgs
nop not in the battlefield ^^
_________________
Nablyudalovka
Group: Banned
Donor:
Gold: Locked
Warn: Banned
Banned
Post#5 Posted: 05 Jul 2010 06:07 pm    Post subject: Reply with quote
First I was like jawdrop
But then I cray
_________________
SoulLove
Group: Banned
Gold: 0.00
Warn: Banned
Banned
Post#6 Posted: 06 Jul 2010 11:23 am    Post subject: Reply with quote
and its works ?
_________________
Own
Gold: Locked
Post#7 Posted: 06 Jul 2010 02:16 pm    Post subject: Reply with quote
dont working here sad
my ip dont get changed by this
Dragonelf
Group: Retired Moderators
Donor:
Gold: 58.70
Clan: Legends
Retired Moderators
Post#8 Posted: 06 Jul 2010 02:24 pm    Post subject: Reply with quote
This will not change your ip, if you use router.
Sun[shine]
Group: Banned
Donor:
Gold: Locked
Banned
Post#9 Posted: 06 Jul 2010 03:23 pm    Post subject: Reply with quote
YePPeD
_________________
Greg
The Random
Group: Banned
Gold: 0.10
Warn: Banned
Banned
Post#10 Posted: 06 Jul 2010 03:26 pm    Post subject: Reply with quote
I'm a fucking pirate.
_________________
Sun[shine]
Group: Banned
Donor:
Gold: Locked
Banned
Post#11 Posted: 06 Jul 2010 05:10 pm    Post subject: Reply with quote
You're fOcking hardcore
_________________
Greg
The Random
Group: Banned
Gold: 0.10
Warn: Banned
Banned
Post#12 Posted: 06 Jul 2010 05:14 pm    Post subject: Reply with quote
You know it babe<3
_________________
ZoiQ
Donor:
Gold: Locked
Post#13 Posted: 06 Jul 2010 05:21 pm    Post subject: Reply with quote
Brrrr
_, ,_ ∩
( ゚∀゚)彡 えーりん!えーりん!
 ⊂彡
[同人音楽部]
View user's profile Send private message Send e-mail Visit poster's website AIM Address MSN Messenger
Nablyudalovka
Group: Banned
Donor:
Gold: Locked
Warn: Banned
Banned
Post#14 Posted: 06 Jul 2010 06:53 pm    Post subject: Reply with quote
Yo, ho, and a bottle of rum.
_________________
Sun[shine]
Group: Banned
Donor:
Gold: Locked
Banned
Post#15 Posted: 08 Jul 2010 02:53 pm    Post subject: Reply with quote
Yo ho?
Pirate-santa? LOL
its ARRRRR ARRR AND A BOTTLE O' RUMMMMMMMM
_________________
bongogocrazy
Group: VIP
Donor:
Gold: 911.10
Clan: Truth
VIP
Post#16 Posted: 16 Jul 2010 04:47 pm    Post subject: Reply with quote
i finally took the time to read the whole 1st post.
i think
is the way to do mine. im gonna try it tonight and see if it works.
i have tried just release - renew and their is a command you type in the start/run/cmd
you type something and it gives you your current ip address. but can't remember. i could never change my ip address.
1 Members: Guest
Post new topic  Reply to topic  d3jsp Forum Index -> Battlefield All times are GMT - 4 Hours
Page 1 of 1
You can download files in this forum
