| Author |
Message |
Vitan
 Group: Scammer Joined: 26 Oct 2007 Donor:  Posts: 4226 Gold: Locked Clan: Legends
Status: Warn:  Reputation: 57
#1 Posted: 09 Apr 2011 03:42 am Post subject: Science contest #1: How much is 1 mole? |
Science contest #1
How much is 1 mole?
Science: Chemistry
PROBLEM: The mole is a unit of measurement for the amount of substance or chemical amount. I can surely say 1 mole of rice could feed whole world for a long time.
Calculate how thin would layer covering Earth made of 1 mole rice grains be, assumed 1 grain is 1 cube centimeter large and circumference of an Earth is 40000 km?
REWARD: Best calculation wins 100 Fg. DEADLINE: May 1st
Last edited by Vitan on 12 Apr 2011 11:08 am; edited 1 time in total _____________________
| Back to top |
Cancerous
 Group: Members Joined: 18 Mar 2011 Donor:  Posts: 233 Gold: 335.73
Status: Warn:  Reputation: 6
#2 Posted: 09 Apr 2011 04:28 am Post subject: |
Surface area = 510,072,000 km2
510,072,000 km2 * (10 * 100 * 1000*)
= 510, 072, 000, 000, 000, 000 cm2
So you would need 510, 072, 000, 000, 000, 000 moles of rice. _____________________
| Back to top |
Vitan
#3 Posted: 09 Apr 2011 06:06 am Post subject: |
| Cancerous wrote: | Surface area = 510,072,000 km2
So you would need 510, 072, 000, 000, 000, 000 moles of rice. |
Cancerous you are not asked to calculate moles, but how thin would layer of 1 mol be. _____________________
| Back to top |
Cancerous
#4 Posted: 09 Apr 2011 06:14 am Post subject: |
Oh...1cm? _____________________
| Back to top |
thecrazykiller
 Group: Members Joined: 22 Mar 2011 Donor:  Posts: 172 Gold: 0.00
Status: Warn:  Reputation: 0
#5 Posted: 09 Apr 2011 03:52 pm Post subject: |
| Cancerous wrote: | | Oh...1cm? | 2 cm _____________________ I will |
| Back to top |
Vitan
#6 Posted: 10 Apr 2011 07:52 am Post subject: |
Bump! _____________________
| Back to top |
Cancerous
#7 Posted: 10 Apr 2011 08:24 am Post subject: |
(Grains of rice per layer) 510 072 000 000 000 000 / (population of earth) 6 770 000 000 000 = 75 342.9838 grains of rice per person.
There's about 3000 grains of rice in a bowl.
75 343/3000 = 75
So that's 75 bowls of rice per person.
Assuming it's rice for breakfast lunch and dinner, that's 25 days of rice supply.
"A long time" is hard, so I'll use a year as an example.
365/25 = 14.6
So that's 14.6 layers of rice.
1 layer = 1cm high
14.6cm deep each year. _____________________
| Back to top |
Basi
Group: Scammer Joined: 03 Dec 2010 Posts: 2403 Gold: Locked
Status: Warn:  Reputation: 62
#8 Posted: 11 Apr 2011 03:02 pm Post subject: |
| Cancerous wrote: | (Grains of rice per layer) 510 072 000 000 000 000 / (population of earth) 6 770 000 000 000 = 75 342.9838 grains of rice per person.
75 343/3000 = 75
365/25 = 14.6
1 layer = 1cm high
14.6cm deep each year. |
A for effort but you're doing the question completely wrong. this has nothing to do with how many people there are in the world, how how much rice they eat. You made it a lot more complicated than it actually is, reread the question. "how thin would the layer of 1 mole of rice around the world which is 40 x 10^3 km?"
This is the answer...
40,000 km = 4,000,000,000 cm
6.02 x 10^23 grains of rice and each grain is (according to OP) 1 cm long so it's a simple 1:1 ratio. area of the world doesn't matter since the circum is given.
so total amount of grain, 6.02 x 10^23 divided by total area available 4 x 10^9 = a layer that is 1.505 x 10^14 cms
Now, assuming you didn't make a typo and that 40.000 you typed is 40 and not 40,000 the answer is different. This is assuming the C you provided is 40km instead of 40,000 km
40 km = 4,000,000 cm
6.02x10^23/4x10^6 = 1.505 x 10^17 cm thick
so if the C is 40,000km = a minimum layer that is 1.505x 10^14 cm
and if the C is 40 km = a minimum layer that is 1.505 x10^17 cm
Edit: This is actually wrong too lol, i'm a moron. check my next post because apparently i forgot 8th grade geometry
| Back to top |
Basi
#9 Posted: 11 Apr 2011 03:38 pm Post subject: |
ok here's the answer, i'm going to assume the circumference you provided is actually 40,000 instead of 40.000 and that it was just a typo
to know how much rice will form a layer to cover the entire world, you need to know what the entire world is. you have to calculate surface area from the given circumference first, a key step i sidestepped in my other post.
C= 2*pi*r, and we must solve for r (radius)
r = C/pi * 2; r = 6369 km
now with this radius, we must calculate surface area (SA)
SA = 4*pi*r^2
SA= 5.0952 x 10^8 cubic km
now cubic km to cubic cm
5.0952 x 10^8 cubic km x 1*10^15 = 5.0952 x 10^23 cubic cm = SA in cubic cm
6.02 x 10^23 cubic cm of rice / 5.0952 x 10^23 cubic cm SA= a layer that is 1.181 cm
and that's the answer, once again assuming a 40,000 circumference |
| Back to top |
Vitan
#10 Posted: 13 Apr 2011 11:25 pm Post subject: |
Bump _____________________
| Back to top |
Cancerous
#11 Posted: 13 Apr 2011 11:38 pm Post subject: |
Why do you need to bump a stickied topic?
Lol. _____________________
| Back to top |
Basi
#12 Posted: 14 Apr 2011 09:48 am Post subject: |
Why do u bump when the correct answer is already there o.O
for shits and giggles I just quadruple checked the math and formulas and it's all right |
| Back to top |
Vitan
#13 Posted: 14 Apr 2011 03:48 pm Post subject: |
I forgot topic is stikied and none of the answers is correct. _____________________
| Back to top |
Basi
#14 Posted: 14 Apr 2011 04:04 pm Post subject: |
| Vitan wrote: | | I forgot topic is stikied and none of the answers is correct. |
1.81cm is right. literally gave it to my physics major friend and he gave me the same answer couple hours after i posted my answer.
idc about the fg, but you better double check your math tootz.
i was trying to be nice but now im slightly annoyed. the question is already extremely flawed because perimeters (aka circumference) is a 2 dimensional measurement and you cannot just transition at will to 3 dimensional measurements. the transition method is extremely flawed. if you calculate the radius given that number it will always be slightly off, and if you attempt to go the 3d route using radians it will be even more off. if you asked how thick would a LINE of rice be around the world (aka a 2 dimensional measurement) then you could have an exact number.
however converting it so SA has a much lower degree for error than going the radian route, so 1.81 is the answer that is the best estimate given the variables you provided.
| Back to top |
Vitan
#15 Posted: 14 Apr 2011 04:13 pm Post subject: |
| Basi wrote: | | Vitan wrote: | | I forgot topic is stikied and none of the answers is correct. |
however converting it so SA has a much lower degree for error than going the radian route, so 1.81 is the answer that is the best estimate given the variables you provided. |
1 mole rice is much more... _____________________
| Back to top |
Basi
#16 Posted: 14 Apr 2011 04:25 pm Post subject: |
1 mole of rice is 6.02 x 10^23 grains...
"6.02 x 10^23 cubic cm of rice / 5.0952 x 10^23 cubic cm SA= a layer that is 1.181 cm"
do you know how many cubic cm there are in this world lol? about a mole's worth |
| Back to top |
Basi
#17 Posted: 29 Apr 2011 01:12 pm Post subject: |
| gave u 2 weeks, plenty o' time to discover the correct answer for yourself dear |
| Back to top |
Red
Group: VIP Joined: 26 Apr 2011 Donor:  Posts: 109 Gold: 4749.14 Clan: Amazing Virgins
Status: Warn:  Reputation: 3
#18 Posted: 29 Apr 2011 02:19 pm Post subject: Re: Science contest #1: How much is 1 mole? |
| Vitan wrote: | Science contest #1
How much is 1 mole?
Science: Chemistry
This question is not worded right at all.
Are you asking how thin/thick would a mole of rice be if it covered the Surface Area of the Earth? |
| Back to top |
Basi
#19 Posted: 29 Apr 2011 02:24 pm Post subject: Re: Science contest #1: How much is 1 mole? |
| Hearts wrote: | | Vitan wrote: | Science contest #1
How much is 1 mole?
Science: Chemistry
yeah that's the only thing he logically could have meant. unless he literally meant how thick a layer would be to cover the circumference which would be a line with zero depth around the world which can't exist. |
| Back to top |
Red
#20 Posted: 29 Apr 2011 02:30 pm Post subject: |
118022.55367869634090873445317524 cubic cm thin
| Back to top |
