i pmed him to clarify, a layer around the world covering every inch of the planet. then he gets confused when people use cubic and squared cm to come up with the answer. the answer itself wouldn't be in squared cm because you have to divide squared by squared at some point to get depth. however he is just completely oblivious to the question he's actually asking. besides the answer he posted wasn't that off. the correct answer is this 1.181 cm, which is 11.81 mm so just a 100 fold ;d
btw hearts you were wrong because you went from reg cm to squared cm but then somehow ended up at cubic cm and i can't see, unless you just meant that to be squared cm which would be wrong anyway
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You can download files in this forum
